Dynamic color change in distance calculation
Leizah
Post by Leizah »
I've a scene with two objects, a table (Object_1) and a walking Bill (Object_2).
I would like to display the minimum distance between these object with a red line when d < 0.5m and a green one when d > 0.5m.
Using this tutorial as reference, I've made the following child script for the table (That's the fixed object into the scene):
    local Object_1_Handle=sim.getObjectHandle('Object_1')
    Object_1_Collection=sim.createCollection(0)
    sim.addItemToCollection(Object_1_Collection,sim.handle_tree,Object_1_Handle,0)
    distanceSegment_true=sim.addDrawingObject(sim.drawing_lines,4,0,-1,1,{0,1,0})
    distanceSegment_false=sim.addDrawingObject(sim.drawing_lines,4,0,-1,1,{1,0,0})
function sysCall_sensing()
    local result,distData,objectPair=sim.checkDistance(Object_1_Collection,sim.handle_all)
    if  result <0.5 then
        sim.addDrawingObjectItem(distanceSegment_false,nil)
        sim.addDrawingObjectItem(distanceSegment_false,distData)
        local txt='Object_1 clearance is '..distData[7]
        txt=txt..'m, minimum distance object pair is '..getAsString(objectPair)
        print(txt)
        sim.addDrawingObjectItem(distanceSegment_true,nil)
        sim.addDrawingObjectItem(distanceSegment_true,distData)
        print(txt)
Unfortunately, the segment doesn't change color when the distance crosses the d = 0.5m value, so it stays red/green if the first calculated value was d < 0.5m / d > 0.5m
There is a way to dinamically change the line color according to the calculated distance between the objects?
Re: Dynamic color change in distance calculation
It should be if distData[7]<0.5 then ... not if result<0.5 then ....
result is 0 or 1 (1 if distance is smaller than threshold).
distData is a table, indices 1 to 6 being the distance segment, and index 7 is the distance between the entities.
Leizah
Post by Leizah »
It worked, thank you!
I would like to extend my scene with another table, and I would like to mantain the distance line between Bill and each teable, adding a green/red panel (like a door) between the two table according to their relative distance, is that achievable using a similiar script?
Yes
You have various item types, e.g. pixel-sized points, pixel-sized lines, triangles, "triangle points", "rectangle points", "disc points", "cube points", "sphere points".
Additionally, you can dynamically create and destroy primitive shapes and meshes.
See also:
Leizah
Post by Leizah »
Thanks,
I knew about that possible solution, but I would like to generate the rectangular mesh fixed between two specific object (If a walking element i.e. Bill passes between these objects, the mesh has not to desappear) and to maintain the line for all the other possible combination.
There's a way to get that kind of result?
Leizah
Post by Leizah »
fferri wrote: 17 Jul 2021, 17:28 Yes
See also:
Hi, I've tried to use the "rectangle points" item, but it returns me a very big area that doesn't link the two minimum distance points (as the line does), but that's set in a random place in the space between the two object.
That's the code I used:
    local Stand_Enter_Handle=sim.getObjectHandle('Stand_Enter')
    Stand_TP_Handle=sim.getObjectHandle('Teach_Pendant_Stand')
    Stand_Exit_Handle=sim.getObjectHandle('Stand_Exit')
    EnterCollection=sim.createCollection(0)
    sim.addItemToCollection(EnterCollection,sim.handle_tree,Stand_Enter_Handle,0)
    TPCollection=sim.createCollection(0)
    sim.addItemToCollection(TPCollection,sim.handle_tree,Stand_TP_Handle,0)
    ExitCollection=sim.createCollection(0)
    sim.addItemToCollection(ExitCollection,sim.handle_tree,Stand_Exit_Handle,0)
    SafeExit_true=sim.addDrawingObject(sim.drawing_cubepoints,0.1,0,-1,1,{0,1,0})
    SafeExit_false=sim.addDrawingObject(sim.drawing_cubepoints,0.1,0,-1,1,{1,0,0,})
    local result,distData,objectPair=sim.checkDistance(EnterCollection,sim.handle_all)
    local result_1,distData_1,objectPair_1=sim.checkDistance(EnterCollection,Stand_TP_Handle)
    local result_2,distData_2,objectPair_2=sim.checkDistance(EnterCollection,ExitCollection)
    local result_3,distData_3,objectPair_3=sim.checkDistance(TPCollection,ExitCollection)
    if  distData[7] <0.5 and distData_1[7]>0.5 and distData_2[7]>0.5 and distData_3[7]>0.5 then
        sim.addDrawingObjectItem(SafeExit_true,nil)
        sim.addDrawingObjectItem(SafeExit_true,distData_1)
        sim.addDrawingObjectItem(SafeExit_true,distData_2)
        sim.addDrawingObjectItem(SafeExit_true,distData_3)
        local txt='Enter clearance is '..distData[7]
        print(txt)
        sim.addDrawingObjectItem(SafeExit_false,nil)
        sim.addDrawingObjectItem(SafeExit_false,distData_1)
        sim.addDrawingObjectItem(SafeExit_false,distData_2)
        sim.addDrawingObjectItem(SafeExit_false,distData_3)
        print(txt)
This is what I get using the sim.drawing_quadpoints type:
This is what I get using the cubepoints type:
I would like to get a rectangle with the same dimension of the green line (that's the distance between the objects) and an height h= 1 m that is green/red according to the minimum distance value, but I was not able to figure out what I've to change my code in order to get what I want.
In addition, I set the code for generate three different cubes, but it only returns one (which has, however, the wrong color, because the distance shown into the picture is d >0.5 m, so it should be green, but, as you can see, it's red)
There's any tutorial to understand properly how the command works when a different item type is selected?
You have several possibilities to create a rectangle or cuboid:
Leizah
Post by Leizah »
coppelia wrote: 22 Jul 2021, 08:18 You have several possibilities to create a rectangle or cuboid:
Hi, thanks or you reply.
Unfortunately, I still don't get how to get it work.
In both solution, I don't know how to set the mesh into the space between the objects.
Using sim.drawing_triangles I've the following description in the regular API page:
items are triangles (9 values per item (x0;y0;z0;x1;y1;z1;x2;y2;z2) + auxiliary values)
How I've to set these values and how I could link that to the distance that I got from the checkDistance command?
Using sim.createPureShape I got a shape at the origin of the reference system, and don't know how to place this shape along the distance line that I've obtained with the sim.drawing_lines command.
Thanks in advance for your help
Well,
you'll have to do some trigonometry and coordinate transformations! You'll have to start with your two points, and figure out where your other 6 points should be, in order to obtain a cuboid.
Leizah
Post by Leizah »
coppelia wrote: 22 Jul 2021, 09:43 Well,
Thank you!
I managed to get the desired shape, but now I would like to set it's trasparency to a 5% value, so i added the sim.drawing_itemtransparency string to the command, but I don't know where I've to write the transparency value.
