This simulation will run with custom simulation parameters
zhy149
Post by zhy149 »
Hello Coppelia,
I got this message box when I tried to run a scene I created a week ago, but I don't remember I did any change to the simulation parameters. Is there anything I should look at or change?
Thank you very much!
Re: This simulation will run with custom simulation parameters
the box says;
This simulation will run with custom simulation parameters. Be aware that you might experience slowdowns or accuracy problems, and some scenes or models will not perform as expected. Whenever possible, it is recommended to keep default simulation parameters (e.g. simulation time step or dynamics settings).
It will appear if you use a simulation time step different from the default (50ms is default), or a dynamics configuration mode different from the default (balanced is default).
