Move multiple joints at one
shreyas7738
Post by shreyas7738 »
How can I move two revolute joints simultaneously?Lua follows a line-by-line approach and I was just wondering if there is a way to move two joints simultaneously.
Re: Move multiple joints at one
Functions such as sim.setJointPosition or sim.setJointTargetPosition return immediately, so if you sequentially set position of joint 1 then position of joint 2, those will move simultaneously (if inside a threaded script, you need to momentarily disable thread switching to make sure simulation doesn't advance in-between the two calls)
shreyas7738
How do I disable thread switching momentarily in remote API?
You can disable thread switching in embedded child scripts.
In case of remote API, you probably want to use synchronous operation.
to disable and enable again thread switching in a threaded script, do something like:
-- temporarily disable thread switching:
fl=sim.setThreadSwitchAllowed(false)
-- enable thread switching again:
sim.setThreadSwitchAllowed(fl)
