Maximum threshold of objects that can be uploaded
cca
Post by cca »
I am currently trying to learn V-rep. For some reason the interface has significantly slowed down.
Is there a maximum threshold of objects that can be uploaded? I have simplified most responable and collidable objects in my scene. Or is there a way to know the overall mesh count of the mentioned objects so at least the user can have an idea how much mesh count is optimal?
Re: Maximum threshold of objects that can be uploaded
your scene shouldn't contain much more than 2000 objects, otherwise you are doing something wrong. If you need to create a lot of individual shapes, then you probably can group some of them to a single entity via sim.groupShapes.
With <ctrl-a> you can select all objects in the scene and immediately see how many there are (displayed at the top of the 3D part). You can also specifically check how many shapes you have in the scene by typing:
sim.getObjectsInTree(sim.handle_scene,sim.object_shape_type)
If a given shape contains a large amount of triangles, then you could also see some slowdowns. Typically, try to create models with 5'000-10'000 triangles. Your whole scene shouldn't contain more than 200'000 to 500'000 triangles. You can check this with following code:
    local l=sim.getObjectsInTree(sim.handle_scene,sim.object_shape_type)
    local mmax=0
    local tot=0
    for i=1,#l,1 do
        local vert,ind=sim.getShapeMesh(l[i])
        tot=tot+#ind/3
        if #ind/3>mmax then
            mmax=#ind/3
    print(string.format("The scene contains a total of %i triangles. The largest shape contains %i triangles",tot,mmax))
