Quadcopter following the path
Re: Quadcopter following the path
you need to localize the bottleneck: what takes most time to execute? Is it the rendering, is it a script, or a specific functionality?
You can use sim.getSystemTimeInMs to check for timings between various parts, e.g.:
local startTime=sim.getSystemTimeInMs(-1)
print(string.format("Took %i[ms] to location A",sim.getSystemTimeInMs(startTime)))
print(string.format("Took %i[ms] to location B",sim.getSystemTimeInMs(startTime)))
etc.
ArthurS
Post by ArthurS »
in principle, when I add 5 drones, fps becomes lower than 10 and slows down everything. Apparently drone scripts are superimposed (they are multithreaded) There are no more computational processes on the stage
Yes, but what exactly is taking computation time? The drone itself can probably be simplified to the bare minimum (i.e. no simulation of wind particles, etc.). For that we need to know where the bottleneck is, and what "slow" means for you. How many frames in a second?
ArthurS
Post by ArthurS »
I forgot about this nasty shadow and wind simulation)). Removed this and everything works smoothly and clearly d 22-23 fps. Cool!!!
How can you raise fps to 60 for clear video recording?
I have a pretty big project. it will be published in a scientific journal. Now I am suffering with such petty difficulties.
You usually do not need a higher Fps in order to record a smooth video, with correct time. Simply use the video recorder that comes with CoppeliaSim (in the left toolbar). The recorder will (by default) record one frame per simulation step. Those settings can of course be changed.
