Line following BubbleRob tutorial dont work
Posted: 15 Sep 2021, 16:11
by lyl
I followed the user's manual to the Line Following BubbleRob tutorial, but one of the things I made was spinning backwards in place for some reason!The code uses the official website——
https://www.coppeliarobotics.com/helpFiles/index.html[img]C:\Users\风继续吹\Desktop\Line following BubbleRob tutorial [/img]
Re: Line following BubbleRob tutorial dont work
Posted: 16 Sep 2021, 07:15
That's correct, but the tutorial scene should contain the working script. Here again for info (that's for CoppeliaSim V4.2.0):
function sysCall_init()
bubbleRobBase=sim.getObjectHandle(sim.handle_self)
leftMotor=sim.getObjectHandle("bubbleRob_leftMotor")
rightMotor=sim.getObjectHandle("bubbleRob_rightMotor")
noseSensor=sim.getObjectHandle("bubbleRob_sensingNose")
minMaxSpeed={50*math.pi/180,300*math.pi/180}
backUntilTime=-1 -- Tells whether bubbleRob is in forward or backward mode
floorSensorHandles={-1,-1,-1}
floorSensorHandles[1]=sim.getObjectHandle("bubbleRob_leftSensor")
floorSensorHandles[2]=sim.getObjectHandle("bubbleRob_middleSensor")
floorSensorHandles[3]=sim.getObjectHandle("bubbleRob_rightSensor")
robotTrace=sim.addDrawingObject(sim.drawing_linestrip+sim.drawing_cyclic,2,0,-1,200,{1,1,0},nil,nil,{1,1,0})
-- Create the custom UI:
xml = '<ui title="'..sim.getObjectName(bubbleRobBase)..' speed" closeable="false" resizeable="false" activate="false">'..[[
<hslider minimum="0" maximum="100" on-change="speedChange_callback" id="1"/>
<label text="" style="* {margin-left: 300px;}"/>
</ui>
ui=simUI.create(xml)
speed=(minMaxSpeed[1]+minMaxSpeed[2])*0.5
simUI.setSliderValue(ui,1,100*(speed-minMaxSpeed[1])/(minMaxSpeed[2]-minMaxSpeed[1]))
function sysCall_sensing()
local p=sim.getObjectPosition(bubbleRobBase,-1)
sim.addDrawingObjectItem(robotTrace,p)
function speedChange_callback(ui,id,newVal)
speed=minMaxSpeed[1]+(minMaxSpeed[2]-minMaxSpeed[1])*newVal/100
function sysCall_actuation()
result=sim.readProximitySensor(noseSensor)
if (result>0) then backUntilTime=sim.getSimulationTime()+4 end
-- read the line detection sensors:
sensorReading={false,false,false}
for i=1,3,1 do
result,data=sim.readVisionSensor(floorSensorHandles[i])
if (result>=0) then
sensorReading[i]=(data[11]<0.5) -- data[11] is the average of intensity of the image
-- compute left and right velocities to follow the detected line:
rightV=speed
leftV=speed
if sensorReading[1] then
leftV=0.03*speed
if sensorReading[3] then
rightV=0.03*speed
if sensorReading[1] and sensorReading[3] then
backUntilTime=sim.getSimulationTime()+2
if (backUntilTime<sim.getSimulationTime()) then
-- When in forward mode, we simply move forward at the desired speed
sim.setJointTargetVelocity(leftMotor,leftV)
sim.setJointTargetVelocity(rightMotor,rightV)
-- When in backward mode, we simply backup in a curve at reduced speed
sim.setJointTargetVelocity(leftMotor,-speed/2)
sim.setJointTargetVelocity(rightMotor,-speed/8)
function sysCall_cleanup()
simUI.destroy(ui)
Posted: 16 Sep 2021, 07:23
by lyl
I tried putting your code into bubbleRob's Child script, but the results didn't change and my three visual sensors were black all the time as if they couldn't pick up the line![img]C:\Users\风继续吹\Desktop[/img]
Posted: 16 Sep 2021, 09:05
So which version of CoppeliaSim are you running? And what platform?
Is there any error message?
Posted: 16 Sep 2021, 09:09
by lyl
coppelia wrote: ↑16 Sep 2021, 09:05
version 4.2.0,. Just inside coopeliasim with the embedded script inside run, no error message.
Posted: 16 Sep 2021, 11:54
Please post your scene. Something must be wrong.
Posted: 17 Sep 2021, 01:59
by lyl
soory!I have not inserted the picture, I wonder if you can see it, if not, please tell me!
Posted: 17 Sep 2021, 05:41
You need to post the scene file, not the picture, if you want us to have a look at it!
Posted: 18 Sep 2021, 06:15
by lyl
Can I transfer files in this forum? How does it work?
Posted: 19 Sep 2021, 11:33
by fferri
Use any file sharing service that allows you sharing a public link, e.g.
Google Drive,
Dropbox,
OneDrive, etc...
