non-static and respondable object keeps moving after droping into a box
wozxfdha
Post by wozxfdha »
I want to deal with the task of grasping in clutter, so I need to drop them into a box. I set each object's properties: non-static, respondable.
If I drop a ball into it, the ball just rolls from side to side and never stops sometimes.
However, I need a static grasp scene.
So what should I do to solve this problem?
Thanks.
Re: non-static and respondable object keeps moving after droping into a box
you have several possibilities: you can add some linear and/or angular damping to your ball. You'd do that in the materials dialog (or via a physics engine related API function).
The other possibility is to detect the ball inside of the basket (e.g. via a proximity sensor) and then disable it within the next second or so. i.e. you would make it static. For grasping, you'd eventually need to make it dynamic again, just before closing the gripper.
cheers
