use 'sim.moveToPose' to control two object move with different position
MaJiamu
Post by MaJiamu »
Hello, I want to control two or more dummies to move along different direction and different distance at the same time. I read the instruction about the API function 'sim.moveToPose' , but it seems that this API function can not do this. Maybe Prismatic joints can do this, but I am preferring the 'sim.moveToPose'. Here is the simplified code:
function callback(m,vel,accel,auxData)
    sim.setObjectMatrix(auxData[1],auxData[2],m)
function moveToPose(obj,relObj,pos,euler,vel,accel)
    local auxData={obj,relObj}
    local mStart=sim.getObjectMatrix(obj,relObj)
    local mGoal=sim.buildMatrix(pos,euler)
    sim.moveToPose(-1,mStart,{vel},{accel},{0.1},mGoal,callback,auxData,{1,1,1,0.1})
    initialP[3]=initialP[3]+0.03*sizeFactor_Z
    moveToPose(dummyHandle1,antBase,initialP,initialO,vel_Z,accel)
    moveToPose(dummyHandle2,antBase,initialP,initialO,vel_Z,accel)
    moveToPose(dummyHandle3,antBase,initialP,initialO,vel_Z,accel)----three dummies can only move one by one rather than simultaneous, this is not what I want.
Thanks for anyone who can help me.
Re: use 'sim.moveToPose' to control two object move with different position
you have at least 3 possibilities:
  • use a threaded child script for each object to move
  • write an alternative function similar to sim.moveToPose: that function merely uses sim.rmlPos, sim.rmlStep and sim.rmlRemove, and you can then write movement functions for n DoFs, or for n objects
  • However the simplest solution would be to have n individual threads running in your child script, similar to:
function sysCall_init()
    local coroutineFuncs={coroutine1Main,coroutine2Main,coroutine3Main}
    coroutines={}
    for i=1,#coroutineFuncs,1 do
        coroutines[i]=coroutine.create(coroutineFuncs[i])
function sysCall_actuation()
    for i=1,#coroutines,1 do
        if coroutine.status(coroutines[i])~='dead' then
            local ok,errorMsg=coroutine.resume(coroutines[i])
            if errorMsg then
                error(debug.traceback(coroutines[i],errorMsg),2)
function cb(pose,vel,accel,handle)
    sim.setObjectPose(handle,-1,pose)
function coroutine1Main()
    local h=sim.getObjectHandle('Cylinder1')
    local maxVel={0.01,0.01,0.01,0.01}
    local maxAccel={0.002,0.002,0.002,0.002}
    local maxJerk={0.001,0.001,0.001,0.001}
    local startQ=sim.getObjectPose(h,-1)
    local goalQ=sim.copyTable(startQ)
    goalQ[3]=goalQ[3]+0.5
    sim.moveToPose(-1,startQ,maxVel,maxAccel,maxJerk,goalQ,cb,h)
function coroutine2Main()
    local h=sim.getObjectHandle('Cylinder2')
function coroutine3Main()
    local h=sim.getObjectHandle('Cylinder3')
For above to work, you'll have to first fix a small bug in sim.moveToPose, which currently is not multi-thread safe. Simply edit lua/sim.lua, around line 584, in function sim.moveToPose:
    local usingMatrices=(#currentPoseOrMatrix>=12)
    if usingMatrices then
replace above with:
    local currentMatrix,targetMatrix
MaJiamu
Post by MaJiamu »
coppelia wrote: 30 Nov 2021, 05:26 Hello,
    coroutines={}
            if errorMsg then
replace above with:
Thanks for ur answer! I prefer the last one. But, I got a new problem. How to switch to other coroutineMain functions from a coroutineMain function? Here is the simplified code:
    local coroutineFuncs={coroutine1Main,coroutine2Main,coroutine3Main,coroutine4Main}
    coroutines={}
            if errorMsg then
function Forward()
    goalQ1=goalQ1+0.5
    goalQ2=goalQ2+0.5
    goalQ3=goalQ3+0.5
    flag_coroutine1Main=1
     flag_coroutine2Main=1
      flag_coroutine3Main=1--the function Forward() can obtain the changed position data, and this data will set the goal
      --position to different objects. Therefore, I give three flag value and I hope that program will go to coroutine1Main,
      --coroutine2Main, and coroutine3Main at same time while the flag value is equal to 1. So that, the three objects can
      --move together with different position data. However, the program seems never jump to the other three coroutineMain function.
	if flag_coroutine1Main==1 then
    local startQ1=sim.getObjectPose(h,-1)
    sim.moveToPose(-1,startQ,maxVel,maxAccel,maxJerk,goalQ1,cb,h)
    else sim,switchThread()
if flag_coroutine2Main==2 then
    local startQ2=sim.getObjectPose(h,-1)
    sim.moveToPose(-1,startQ,maxVel,maxAccel,maxJerk,goalQ2,cb,h)
if flag_coroutine3Main==1 then
    local startQ3=sim.getObjectPose(h,-1)
    sim.moveToPose(-1,startQ,maxVel,maxAccel,maxJerk,goalQ3,cb,h)
function coroutine4Main()
    --some initial parameters
    while true do
        if index then
            if index==1 and flag_Loop==0 then
                index=nil
                Forward()
                else if index==1 and flag_Loop==1 then
                Forward()
            sim.switchThread()
the function Forward() can obtain the changed position data, and this data will set the goal position to different objects. Therefore, I give three flag value and I hope that program will go to coroutine1Main, coroutine2Main, and coroutine3Main at same time while the flag value is equal to 1. So that, the three objects can move together with different position data. However, the program seems never jump to the other three coroutineMain function.
You can't call another coroutine/thread from a coroutine/thread. You'll have to work by organizing your coroutines as workers, that can be triggered/activated with specific variables for instance:
function coroutineMain()
    while true do
        if commandPending then
            -- handle pending command
            commandPending=nil
            sim.switchThread()
With my previous code example, that could look like:
    sim.setThreadAutomaticSwitch(false)
    coroutine1TargetPos=nil
    coroutine2TargetPos=nil
    coroutine3TargetPos=nil
    coroutines={}
            if errorMsg then
    coroutine1TargetPos={0,0,1}
    coroutine2TargetPos={0,0.1,1}
    coroutine3TargetPos={0,0.2,1}
    while true do
        if coroutine1TargetPos then
            goalQ[1]=coroutine1TargetPos[1]
            goalQ[2]=coroutine1TargetPos[2]
            goalQ[3]=coroutine1TargetPos[3]
            sim.switchThread()
    while true do
        if coroutine2TargetPos then
            goalQ[1]=coroutine2TargetPos[1]
            goalQ[2]=coroutine2TargetPos[2]
            goalQ[3]=coroutine2TargetPos[3]
            sim.switchThread()
    while true do
        if coroutine3TargetPos then
            goalQ[1]=coroutine3TargetPos[1]
            goalQ[2]=coroutine3TargetPos[2]
            goalQ[3]=coroutine3TargetPos[3]
            sim.switchThread()
MaJiamu
Post by MaJiamu »
coppelia wrote: 02 Dec 2021, 10:30 You can't call another coroutine/thread from a coroutine/thread. You'll have to work by organizing your coroutines as workers, that can be triggered/activated with specific variables for instance:
    while true do
            commandPending=nil
            sim.switchThread()
    coroutines={}
            if errorMsg then
    while true do
            sim.switchThread()
    while true do
            sim.switchThread()
    while true do
            sim.switchThread()
Thanks for detail answer! Finally, I choose the second method to rewrite a new function similar to sim.moveToPose. Here is the simplified code:
----------------------prepare parameters-----------------------
function parafornewMove(Object1changeP,Objec2changeP,Object3changeP)
    para1={Object1initialP[1],Object1initialP[2],Object1initialP[3],0,0,0,0,0,0}
    para2={Object2initialP[1],Object2initialP[2],Object2initialP[3],0,0,0,0,0,0}
    para3={Object3initialP[1],Object3initialP[2],Object3initialP[3],0,0,0,0,0,0}
    para4={para1[1]+Object1changeP[1],para1[2]+Object1changeP[2],para1[3]+Object1changeP[3],0,0,0}
    para5={para2[1]+Object2changeP[1],para2[2]+Object2changeP[2],para2[3]+Object2changeP[3],0,0,0}
    para6={para3[1]+Object3changeP[1],para3[2]+Object3changeP[2],para3[3]+Object3changeP[3],0,0,0}
    para7=ObjectHandle1
    para8=ObjectHandle2
    para9=ObjectHandle3
    return para1,para2,para3,para4,para5,para6,para7,para8,para9
------------------------new moveToPose function--------------------------------
function moveToPose2(currentPosVelAccel1,currentPosVelAccel2,currentPosVelAccel3,targetPosVel1,targetPosVel2,targetPosVel3,h1,h2,h3)--Not UI function----For GoLeft/GoRight move.(moveToPose2)
    local maxVelAccelJerk={vel_X,vel_Y,vel_Z,accel_X,accel_Y,accel_Z,0,0,0}
    -- vx,vy,vz in m/s, ax,ay,az in m/s^2, jx,jy,jz is ignored (i.e. infinite) with RML type 2
    --in this function, maxVelAccelJerk was set to the same value in three Objects
    local rmlObject1=sim.rmlPos(3,0.0001,-1,currentPosVelAccel1,maxVelAccelJerk,{1,1,1},targetPosVel1)
    local rmlObject2=sim.rmlPos(3,0.0001,-1,currentPosVelAccel2,maxVelAccelJerk,{1,1,1},targetPosVel2)
    local rmlObject3=sim.rmlPos(3,0.0001,-1,currentPosVelAccel3,maxVelAccelJerk,{1,1,1},targetPosVel3)
    local lb=sim.setThreadAutomaticSwitch(false)
    result=0
    while result==0 do
        result,newPosVelAccel1=sim.rmlStep(rmlObject1,sim.getSimulationTimeStep())
        result,newPosVelAccel2=sim.rmlStep(rmlObject2,sim.getSimulationTimeStep())
        result,newPosVelAccel3=sim.rmlStep(rmlObject3,sim.getSimulationTimeStep())
        if result~=-1 then
            sim.setObjectPosition(h1,sim.handle_parent,newPosVelAccel1) ----the movement reference in this function was set to sim.handle_parent
            sim.setObjectPosition(h2,sim.handle_parent,newPosVelAccel2)
            sim.setObjectPosition(h3,sim.handle_parent,newPosVelAccel3)
        sim.switchThread()
    sim.setThreadAutomaticSwitch(lb)
    sim.rmlRemove(rmlObject1)
    sim.rmlRemove(rmlObject2)
    sim.rmlRemove(rmlObject3)
--------------------------callback the new function to move three object in a thread------------------------
para1,para2,para3,para4,para5,para6,para7,para8,para9=parafornewMove1(object1changeP,objec2changeP,object3changeP)
moveToPose2(para1,para2,para3,para4,para5,para6,para7,para8,para9)
