WMR control in V-REP
mhr_azizi
Post by mhr_azizi »
Hello friends,
I have modeled a wheeled mobile robot (WMR) in CoppeliaSim and write a code
in Lua to control the position of the robot in the world coordinate frame
using feedback linearization approach. First, I have simulated my
controller in MATLAB and evaluate the feedback control law. Then I have written a
code in V-REP to control the robot motion. However, the Controller is
merely stable when I use the negative gains in my controller. while the
error dynamics is in the form (de/dt+k*e=0) and the simulation in MATLAB shows that the closed loop system is stable for k>0, I can't understand how the robot is stable using negative k<0 in CoppeliaSim. I obtain the same simulation results in CoppeliaSim when I use the gains used in MATLAB but with minus sign.
here is the code I developed in Lua.
      R=.05
      L=.181
      d=3.334e-2
      R1_handle=sim.getObjectHandle("R1")
      R2_handle=sim.getObjectHandle("R2")
      Robot_handle=sim.getObjectHandle("Dummy")
function sysCall_actuation()
      P=sim.getObjectPosition(Robot_handle,-1)
      O=sim.getObjectOrientation(Robot_handle,-1)
      q={P[1],P[2],O[3]}
      qd,dqd=DesiredTrajectory(sim.getSimulationTime())
      U=FeedbackControl(q,qd,dqd,-1,-1,R,L,d)
      u1=U[1]
      u2=U[2]
      sim.setJointTargetVelocity(R1_handle,u1)
      sim.setJointTargetVelocity(R2_handle,u2)
function sysCall_sensing()
      -- put your sensing code here
function sysCall_cleanup()
      -- do some clean-up here
function DesiredTrajectory(t)
      t=sim.getSimulationTime()
      x=.5*math.cos(.2*t)
      y=math.sin(.2*t)
      dx=-.5*.2*math.sin(.2*t)
      dy=.2*math.cos(.2*t)
      qd={x,y}
      dqd={dx,dy}
      return qd,dqd
function FeedbackControl(q,qd,dqd,k1,k2,R,L,d)
      x=q[1]
      y=q[2]
      Teta=q[3]
      xd=qd[1]
      yd=qd[2]
     dxd=dqd[1]
      dyd=dqd[2]
      Input ={(L*dyd*math.cos(Teta) - L*dxd*math.sin(Teta) +
            2*d*dxd*math.cos(Teta) + 2*d*dyd*math.sin(Teta) - L*k2*y*math.cos(Teta) +
            L*k2*yd*math.cos(Teta) + L*k1*x*math.sin(Teta) - L*k1*xd*math.sin(Teta) -
            2*d*k1*x*math.cos(Teta) + 2*d*k1*xd*math.cos(Teta) -
           2*d*k2*y*math.sin(Teta) +
           2*d*k2*yd*math.sin(Teta))/(2*R*d),(L*dxd*math.sin(Teta) -
           L*dyd*math.cos(Teta) + 2*d*dxd*math.cos(Teta) + 2*d*dyd*math.sin(Teta) +
           L*k2*y*math.cos(Teta) - L*k2*yd*math.cos(Teta) - L*k1*x*math.sin(Teta) +
           L*k1*xd*math.sin(Teta) - 2*d*k1*x*math.cos(Teta) + 2*d*k1*xd*math.cos(Teta)
           - 2*d*k2*y*math.sin(Teta) + 2*d*k2*yd*math.sin(Teta))/(2*R*d)}
      return Input
Re: WMR control in V-REP
not entering into details of the specificities of your algorithm, please check if the problem is merely a sign problem, i.e. that for any k, you would get the same results in Matlab or CoppeliaSim, but with a different sign. If this is the case, then you probably have inverted something in your modelling. The only CoppeliaSim outputs are the robot's position and orientation, and the only CoppeliaSim inputs are joint target velocities.
Keep in mind that in CoppeliaSim a joint's force/torque can't be signed. Only the related target velocity can be signed.
