How to add the user-defined control algorithm for the IK?
zhangm365
Post by zhangm365 »
Hello, admin
Now, I am trying to use the customed algorithm for IK control problem to replace with the build-in IK method DLS.
So, what are the key points of the process? i.e, the whole framework of the program, parameter setting, etc
Can you give me a hand?
Best Wishes.
Re: How to use the user-defined control algorithm for the IK?
the best would be to fork and modify the Coppelia kinematics routines, and its related CoppeliaSim IK plugin.
zhangm365
Re: How to add the user-defined control algorithm for the IK?
Post by zhangm365 »
Are there any guidance documents? I am trying to add a user-defined IK method to imitate the build-in method, i.e, DLS.
Best Wishes.
Have a look at the bottom part of the section on plugins: there are several example projects, the most straightforward is probably this one, which basically just adds a new script function.
zhangm365
Post by zhangm365 »
ok, Thanks your reply.
Now, I still have a lot doubt that I don't understand the process you have given above.
coppelia wrote: 25 Jan 2022, 10:03 Hello,
coppelia wrote: 26 Jan 2022, 16:30 Have a look at the bottom part of the section on plugins: there are several example projects, the most straightforward is probably this one, which basically just adds a new script function.
Please allow me to reformulate my problem as follow:
I am trying to use a customed inverse-kinematic algorithm instead of the built-in algorithm (DLS) to calculate the inverse kinematics. Of course, I need to imatate the original algorithm(DLS) so as to add the new calculate method.
How can I do and what is the guiding route of this process?
Best wishes.
clone coppeliaKinematicsRoutines to your programming folder. then clone simExtIK to your programming folder. Then try to build simExtIK. That's the first step.
The second step would be to modify those two items above.
Then add a new define for your new calculation method in coppeliaKineamticsRoutines/ik.h, near ik_method_undamped_pseudo_inverse. In the whole source code search for appearances of ik_method_undamped_pseudo_inverse and insert your new method here and there.
Then in simExtIK/simExtIK.cpp, add a corresponding entry near:
simRegisterScriptVariable("simIK.method_undamped_pseudo_inverse@simExtIK",std::to_string(ik_method_undamped_pseudo_inverse).c_str(),0);
zhangm365
Post by zhangm365 »
Thanks a lot for your guidance. I try it now away.
Best wishes.
zhangm365
Post by zhangm365 »
Dear admin:
Now, I want to express the formula of the joint angle \(\boldsymbol \theta\) as follow:
\(\dot{\boldsymbol \theta}(t)=\boldsymbol J^\dagger (\dot{\boldsymbol p}_d(t)+\gamma (\boldsymbol p_d(t)-\boldsymbol p_a(t))) \label{tracking}\).
Unlike the DLS method form, \(||\boldsymbol J\bigtriangleup {\boldsymbol \theta} - \boldsymbol e||^2 + \lambda^2||\bigtriangleup {\boldsymbol \theta}||^2\), its final expression only include the Jacobian matrix and can be easily written.
The \(\dot{\boldsymbol p}_d(t)\) stands for the velocity of the desired path, how should it be represented in source code in my case?
Best Wishes.
You will have to look at the source code around this line, and figure out where to plug in your part.
zhangm365
Post by zhangm365 »
Well, I noticed that it is where the code should be inserted.
However, I mean the formula in my case as follow:
\(\dot{\boldsymbol \theta}=\boldsymbol J^\dagger (\dot{\boldsymbol p}_d+\gamma (\boldsymbol p_d-\boldsymbol p_a)) \) .
i.e, the variable \(\dot{\boldsymbol p}_d\) ( the velocity of the target position ) is how to be represented?
