ros getobjecthandle
btz
ros getobjecthandle
Post by btz » 05 Nov 2013, 14:16
I have a little trouble understanding in the API how i have to write the code to get an objecthandle by name.
Could anyone provide me with a little code example how to get an object named "sensor" or so?
Thank you in advance.
Re: ros getobjecthandle
Post by coppelia » 06 Nov 2013, 14:08
to retrieve the handle of an object, you can do:
  • From a child script, an add-on, or a plugin:
    handle=simGetObjectHandle("objectName")
  • From a remote API client (e.g. C/C++):
    int handle;
    int errorCode=simxGetObjectHandle(clientId,"objectName",&handle,simx_opmode_oneshot_wait);
  • From a ROS node:
    ros::ServiceClient client_getObjectHandle=node.serviceClient<vrep_common::simRosGetObjectHandle>("/vrep/simRosGetObjectHandle");
    vrep_common::simRosGetObjectHandle srv_getObjectHandle;
    srv_getObjectHandle.request.objectName="objectName";
    if ( client_getObjectHandle.call(srv_getObjectHandle))
    	int handle=srv_getObjectHandle.handle;
omar khalfaoui
Post by omar khalfaoui » 13 Mar 2014, 11:53
I just would like to add a quesiton:
for instence, I would like to create a ROS node that allows me to control the posotion of a dummy in the simulation.
if I'm not wrong,
First: I need to create the comunication using
ros::ServiceClient client_enableSubscriber=n.serviceClient<vrep_common::simRosEnableSubscriber>("/vrep/simRosEnableSubscriber");
vrep_common::simRosEnableSubscriber srv_enableSubscriber;
srv_enableSubscriber.request.topicName="creaDummy"; // the topic name
srv_enableSubscriber.request.queueSize=1; // the subscriber queue size (on V-REP side)
Second: I need to retrieve the handle of the object:
Third: check if the service call was ok, and the subscriber was succesfully started on V-REP side.
if (client_enableSubscriber.call(srv_enableSubscriber)&&(srv_enableSubscriber.response.subscriberID!=-1))
Now, inside the seconde if, i need to use the handle. Let's say I want to change the x-value of the dummy. can I use a command similar to the followint?:
[i]int handle=srv_getObjectHandle.position.x [/i]
The thing is that i would like to use only a ROS node to handle everything in VREP. I don't know if it's possible or not.
PS: in my case, is it better to use a threaded or a non-thereaded childscript?
Thank you very much for the Help.
have a nice day
Post by coppelia » 13 Mar 2014, 16:31
See your other post/my other reply
