Interact with .obj file properly?
zhy149
Post by zhy149 »
Hello, I found some .obj files online and just import them to coppeliasim directly, but it doesn't seem I can grasp them, is there any setting I should modify to successfully interact with .obj files just like pure shapes?
Thank you!
zhy149
Re: Interact with .obj file properly?
Post by zhy149 »
Nvm I got it, I need to set it to be dynamic.
Keep in mind that random shapes will perform very poorly when simulated with a physics engine (slow, and not stable). Try to use primitive shapes or convex shapes instead (or a compound of primitive or convex shapes): you can still use the original shape for the visual part, but use a simplified representation of it in a hidden layer, e.g.:
simplifiedDynamicShape --> originalStaticShape
Read more about this in the design considerations on building a dynamics simulatiuon
