v_repExtRos not working on OS X and Windows
After building v_repExtRos plugin for OS X, it fails to load, because it will look for libv_repExtRos.so, instead of libv_repExtRos.dylib.
I changed the part where it will unconditionally look for the ".so" file, with the corresponding part from v_repExtK3, which is macro based and will look for the correct library for the current platform. (See attached patch)
I don't know if there is ROS for Windows yet, but I just built ROS Indigo for OS X and now I'm playing with ROS, V-REP and v_repExtRos :-)
Patch:
--- vrep_plugin/src/vrep_plugin.cpp.orig	2015-03-26 17:53:10.000000000 +0100
+++ vrep_plugin/src/vrep_plugin.cpp	2015-03-26 17:52:14.000000000 +0100
@@ -318,7 +318,14 @@ VREP_DLLEXPORT unsigned char v_repStart(
 	std::string currentDirAndPath(curDirAndFile);
 	// 2. Append the V-REP library's name:
 	std::string temp(currentDirAndPath);
+#ifdef _WIN32
+	temp+="\\v_rep.dll";
+#elif defined (__linux)
 	temp+="/libv_rep.so";
+#elif defined (__APPLE__)
+	temp+="/libv_rep.dylib";
+#endif /* __linux || __APPLE__ */
 	// 3. Load the V-REP library:
 	vrepLib=loadVrepLibrary(temp.c_str());
Re: v_repExtRos not working on OS X and Windows
Thanks again Federico,
you are right. The plugin was actually initially not meant for a different platform that Linux ;)
