Omniwheel robot rolling down an inclined plane
lshachar
Post by lshachar »
This is related to my previous post:
viewtopic.php?f=9&t=4045
I am trying to get a three-wheel omnidirectional robot to roll down an inclined plane.
I set all three motors with zero speed and zero torque, to make the main axis of the omnidirectional wheel (the rolling axis) free.
I also commented out the main robot's script, not to set any target velocites to the omnidirectional wheels.
The robot rolls down very, very slowly. And I can't figure out why.
(as can be seen in the simulation, the robot on the right)
I then proceeded to make a simplified platform, with one omnidirectional wheel replaced with a frictionless caster, and the two remaining omni wheels in parallel to each other. (in the simulation seen on the right)
-The robot is still considerably slower than the modeled rolling sphere.
Why so? what can I do to fix this behavior?
Thank you for your help! :)
https://dl.dropboxusercontent.com/u/256 ... 20roll.ttt
lshachar
Re: Omniwheel robot rolling down an inclined plane
Post by lshachar »
I think that the issue is the joints being reset in every step of the simulation, meaning that they don't carry their velocity while spinning. This also explains why when I made the base plate much heavier, the effect was reduced. I wonder if this is really the problem and whether there are other common ways to model an omni wheel.
you are right, one element in each wheel is always reset, thus always starts at linear/rotational velocity zero. The construction is more meant to be used in an active way (with the main axis driving the wheel). You can improve this in several ways:
  • Reduce the mass/inertia of the wheels that get reset
  • Apply an initial linear/angular velocity to the wheels that get reset
Your code is based on an old V-REP version (and had a bug), use following instead:
	rolling=simGetObjectAssociatedWithScript(sim_handle_self)
	slipping=simGetObjectHandle('OmniWheel_freeJoint')
	wheel=simGetObjectHandle('OmniWheel_respondableWheel')
	if (simGetObjectParent(rolling)~=-1) then
		local linVel,angVel=simGetVelocity(wheel)
		simResetDynamicObject(wheel)
		simSetObjectFloatParameter(wheel,3000,linVel[1])
		simSetObjectFloatParameter(wheel,3001,linVel[2])
		simSetObjectFloatParameter(wheel,3002,linVel[3])
		simSetObjectFloatParameter(wheel,3020,angVel[1])
		simSetObjectFloatParameter(wheel,3021,angVel[2])
		simSetObjectFloatParameter(wheel,3022,angVel[3])
		simSetObjectPosition(slipping,rolling,{0,0,0})
		simSetObjectOrientation(slipping,rolling,{0,math.pi/2,0})
		simSetObjectPosition(wheel,rolling,{0,0,0})
		simSetObjectOrientation(wheel,rolling,{0,0,0})
In above code, an initial linear/angular velocity is applied to your wheels.
Then: the free joints should be in force/torque mode, but the motor NOT enabled. If the motor is enabled, a physics engine will often still apply a force/torque to such a joint when the target velocity is zero, which can be used to simulate friction, but which is of no interest in your situation.
lshachar
Post by lshachar »
Thank you very much! I would never have figured out by myself how to save the linear / angular velocities before resetting the wheel, and applying them back afterwards. I ended up modeling the omniwheels differently, Changing materials with different coefficient of friction from 0 to 1, and reapplying the velocities is a necessary step.
thank you
