UnsatisfiedLinkError Mac OS by calling simxStart
BrainDead
Post by BrainDead »
I try to use the Java remoteAPi under Mac OS 10.6.8 (V-Rep version: 3.0.3)
I put the libremoteApi.dylib into the java.library.path:
.:/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java
Plugin for remoteApi is installed and I can start it with simExtRemoteApiStart(19999,250,true).
I created a Java-Project with eclipse and added the remoteApi.java and simpleTest.java (changed name to RemoteMain) files.
The project gets compiled but throws the following exception by calling
int clientID = vrep.simxStart("127.0.0.1",19999,true,true,5000,5);
Exception in thread "main" java.lang.UnsatisfiedLinkError: control.remoteApi.simxStart(Ljava/lang/String;IZZII)I
at control.remoteApi.simxStart(Native Method)
at control.RemoteMain.main(RemoteMain.java:14)
The remoteApi is loaded.
I also compiled the dylib on my computer but get the same exception.
What can I do?
Re: UnsatisfiedLinkError Mac OS by calling simxStart
Are you sure that the libremoteApi.dylib is found?
Also, in remoteApi.java, in the beginning, try to specify the library name with System.loadLibrary("libremoteApiJava"); or System.loadLibrary("libremoteApiJava.dylib");
BrainDead
Post by BrainDead »
I'm sure that the dylib is in the path and is found.
System.loadLibrary("remoteApiJava");
doesn't throw an exception. The call to simxStart does throw.
When I change
to
I get:
Exception in thread "main" java.lang.UnsatisfiedLinkError: no libremoteApiJava in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1758)
at java.lang.Runtime.loadLibrary0(Runtime.java:823)
at java.lang.System.loadLibrary(System.java:1045)
at control.remoteApi.<clinit>(remoteApi.java:30)
at control.RemoteMain.main(RemoteMain.java:13)
Same exception with:
Well,
you are right! We probably forgot to clean before building remoteApiJava.dylib after building remoteApi.dylib. Cleaning and rebuilding will solve your problem. Or you can use this on:
BrainDead
Post by BrainDead »
I get same exception with attached lib.
Is any other rebuild neccessary?
That is strange.
I tried with the old file and got the same error as you. With this file it works fine. Could you try to recompile it yourself?
In the programming folder type:
make -f remoteApiSharedLibJava_makefile clean
You will probably have to adjust the location of the java include folder.
BrainDead
Post by BrainDead »
Ok, I cleaned and rebuild the remoteApiJava:
Knee-deep-in-the-blood:programming user$ make -f remoteApiSharedLibJava_makefile clean
Cleaning remoteApi/extApi.o remoteApi/extApiPlatform.o remoteApiJava.dylib
Compiling remoteApi/extApi.c to remoteApi/extApi.o
remoteApi/extApi.c: In function ‘jint Java_remoteApi_test(JNIEnv*, _jobject*, jint, _jobject*, _jobject*, jint)’:
remoteApi/extApi.c:5322: warning: unused variable ‘theClientID’
Compiling remoteApi/extApiPlatform.c to remoteApi/extApiPlatform.o
Linking remoteApi/extApi.o remoteApi/extApiPlatform.o to remoteApiJava.dylib
I copied the dylib to the java.library.path:
But still I get the same exception:
at control.RemoteMain.main(RemoteMain.java:19)
I put the load call to the constructor to catch a possible exception during load of the library (load or loadLibrary doesn't make a differnce):
public remoteApi ()
		try
			System.load("/System/Library/Java/Extensions/libremoteApiJava.dylib");
		catch (java.lang.UnsatisfiedLinkError e)
			e.printStackTrace();
	/*static{
		//System.loadLibrary("remoteApiJava");
No exception is thrown during loading.
The exception ist thrown when I call a native function of the library:
try
I catch the exception but get no more details then above. The stack trace is null.
Do the *.cpp method signatures exactly match those in the *.h file?
The spec to the UnsatisfiedLinkError says:
Thrown if the Java Virtual Machine cannot find an appropriate native-language definition of a method declared native.
Hello again,
Difficult to debug since it is working here. But maybe try to append extern "C" in front of each JNIEXPORT as suggested in this post.
Can you try with following file? You might have to rename the library to what you had previously, and make sure the correct library is loaded.
BrainDead
Post by BrainDead »
Thanks a lot!
The new lib is working.
