Recommendations on getting started with VREP/Arduino
Re: Recommendations on getting started with VREP/Arduino
Sometimes there is a buffer that is being sent only when there is enough data in it. Try to send continuously data from your Arduino, and see if you can read something.
dnahar
Post by dnahar »
This is not at all helping. I come to the forum, only when i have tried myself many things and couldn't figure out a solution. Could you please help me with the code just to receive simple numbers from arduino and display it on custom user interface? I am able to send code to arduino, but cant receive anything.
(note: receiving of arduino data can be seen on serial monitor of arduino, that means arduino is sending data)
Thanks,
Dixit
Eric
Post by Eric »
Please refer to my post on the first page of this thread to find your answer!
Eric
dnahar
Post by dnahar »
Hello Eric,
Your posts and video is very helpful. I developed the code based on the arduino esplora mode and seeing the video only. I have posted my code in my previous posts here. The problem is i cant receive any information from arduino to vrep, i am able to send it to arduino. This doesnt make sense to me, i have tried many ways. Could you look into my code and suggest me the solution.
Or could you give me a simple code in arduino and vrep, that gets some simple information from arduino and i can display it in vrep.
This is quite an emergency now.
Thanks,
Dixit
Eric
Post by Eric »
The serial monitor of the arduino is not running when you are sending the data to V-REP right? You know that if you do so the port of com would already be used and V-REP could never connect and receive data ....
dnahar
Post by dnahar »
No Sir. I just quoted about the serial monitor to tell that Arduino does send data which I can see on serial monitor.
Again, the problem is that I can send data using serial communication from vrep to arduino but I cant receive any data sent from arduino to vrep using serial communication.
Dixit, please be aware that you probably use the free version of V-REP, you also get free support. Then, we are not from the Arduino company, we don't even have an Arduino here, so our possibilities are limited. Your questions are vague and we don't have all the code you are using to do the writing and reading (e.g. Arduino-side code).
dnahar
Post by dnahar »
I understand. I admire VREP and propagate it to be an excellent package with a responsive forum. I only wish it to grow.
I have posted vrep and arduino code in my previous posts here, i just ask if my code on vrep side is correct and sufficient to receive any data from arduino or do i have to add anything to it?
The problem may be similar to this : http://forum.arduino.cc/index.php?topic=50266.0
and alongwith, i am facing this problem that as i set the label in a non-threaded script within "while (simGetSimulationState()~=sim_simulation_advancing_abouttostop) do" using "simSetUIButtonLabel(uiHandle,27,"100","")", the label 27 just blinks with value 100 once after i stop the simulation. During the simulation it doesnt become 100 which it should be. Could you suggest something here?
Thanks,
Dixit
About the label problem: if you stop the simulation, a threaded child script will break out its various routines, and might still execute some other code in the sequence. That's what is probably happening. Also, try to use print statements in your child script to see if a command is really executed (you can check the console window to see if your prints appear). You can of course also use simAddStatusbarMessage or simAuxiliaryConsoleOpen or similar. Always check the status bar for error messages!
dnahar
Post by dnahar »
while in this loop : "while (simGetSimulationState()~=sim_simulation_advancing_abouttostop) do" in the threaded child script, i want to read the values from arduino using serial comm, and print it on console.
1. I am able to print it just once, and i can see it in the console window only when i stop the simulation. This tells me that it is not running in a loop and executing just once. This might be the reason i am not receiving anything from arduino. It is supposed to run many times in a loop, right? I cross-checked it creating a non-threaded child scripts and i could see lot of values on the console window which asssures me the non-threaded child script is running in loop.
Why is my threaded child script not looping??
2. I am not able to access variables initialized in the initialization phase, in non-threaded child script.
-- DO NOT WRITE CODE OUTSIDE OF THE if-then-end SECTIONS BELOW!! (unless the code is a function definition)
portNumber="\\\\.\\COM4"
-- for serial port
baudrate=9600
serial=simSerialOpen(portNumber,baudrate)
		print(serial)
-- for UI
--if (simGetScriptExecutionCount()==0) then
   uiHandle=simGetUIHandle('UI')
--end
button,auxData=simGetUIEventButton(uiHandle)
-- update sensor weights
--for i = 1,9,1 do
	str0 = simSerialRead(serial,100,false,'\n',100)
	simSetUIButtonLabel(uiHandle,25,str0,"")
	simSetUIButtonLabel(uiHandle,29,"100","")
--end
	if str0 ~= nil then
		print(str0)
		simSetUIButtonLabel(uiHandle,27,str0,"")
		--simSetUIButtonLabel(uiHandle,27,"100","")
if (button==3) then
	signal='9'
	simSerialSend(serial,signal)
elseif (button==47) then
--	serial=simSerialOpen(portNumber,baudrate)
	signal="R"
	str0 = simSerialRead(serial,100,false,'\n',1000)
	print(str0)
	print('10')
--thats it for UI
	-- Put your main ACTUATION code here
	-- For example:
	-- local position=simGetObjectPosition(handle,-1)
	-- position[1]=position[1]+0.001
	-- simSetObjectPosition(handle,-1,position)
	-- Put your main SENSING code here
	-- Put some restoration code here
Throws error on accessing "serial" in the actuation phase.
Thanks,
Dixit
