ROS interface compilation fail
vakker
Post by vakker »
Hi
I tried using the ROS interface, but for the precompiled version it said:
/opt/V-REP_PRO_EDU_V3_3_1_64_Linux/vrep: symbol lookup error: /opt/V-REP_PRO_EDU_V3_3_1_64_Linux/libv_repExtRosInterface.so: undefined symbol: _ZN3ros4initERiPPcRKSsj
so I tried to compile it, but I get an error:
make[2]: *** No rule to make target 'v_repExtRosInterface/CMakeFiles/v_repExtRosInterface.dir/build'. Stop.
CMakeFiles/Makefile2:6727: recipe for target 'v_repExtRosInterface/CMakeFiles/v_repExtRosInterface.dir/all' failed
make[1]: *** [v_repExtRosInterface/CMakeFiles/v_repExtRosInterface.dir/all] Error 2
What am I doing wrong?
Re: ROS interface compilation fail
what instructions do you use to build the packages? Did you make sure the ROS workspace is correctly configured?
You need to use the catkin build tools.
If you didn't modify the package source, then try with something like:
source /opt/ros/indigo/setup.bash ** or source /opt/ros/jade/setup.bash, etc. **
rm -r -f ~/catkin_ws/*  ** completely clean the workspace first **
mkdir ~/catkin_ws/src
cd ~/catkin_ws/src
catkin_init_workspace
cd ..
catkin build
source devel/setup.bash
** copy v_repExtRosInterface folder (or/and the other packages) into ~/catkin_ws/src **
catkin build
vakker
Post by vakker »
Thanks for the reply.
Yep, I'm doing exactly the same, except there is no catkin build in release Kinetic (or I just can't find it? see http://wiki.ros.org/ROS/Tutorials/catki ... ngPackages), so I ran catkin_make as the last step as well.
It gives an error:
-- ~~  traversing 8 packages in topological order:
-- ~~  - ros_bubble_rob2
-- ~~  - vrep_common
-- ~~  - vrep_joy
-- ~~  - vrep_plugin
-- ~~  - vrep_ros_interface
-- ~~  - vrep_skeleton_msg_and_srv
-- ~~  - vrep_plugin_skeleton
-- +++ processing catkin package: 'ros_bubble_rob2'
-- ==> add_subdirectory(ros_bubble_rob2)
-- +++ processing catkin package: 'vrep_common'
-- ==> add_subdirectory(vrep_common)
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- vrep_common: 8 messages, 97 services
-- +++ processing catkin package: 'ros_bubble_rob'
-- ==> add_subdirectory(ros_bubble_rob)
-- +++ processing catkin package: 'vrep_joy'
-- ==> add_subdirectory(vrep_joy)
-- +++ processing catkin package: 'vrep_plugin'
-- ==> add_subdirectory(vrep_plugin)
-- +++ processing catkin package: 'vrep_ros_interface'
-- ==> add_subdirectory(v_repExtRosInterface)
-- +++ processing catkin package: 'vrep_skeleton_msg_and_srv'
-- ==> add_subdirectory(vrep_skeleton_msg_and_srv)
-- vrep_skeleton_msg_and_srv: 0 messages, 1 services
-- +++ processing catkin package: 'vrep_plugin_skeleton'
-- ==> add_subdirectory(vrep_plugin_skeleton)
-- Configuring done
CMake Error at v_repExtRosInterface/CMakeLists.txt:36 (add_library):
  Cannot find source file:
    generated/ros_msg_io.cpp
  Tried extensions .c .C .c++ .cc .cpp .cxx .m .M .mm .h .hh .h++ .hm .hpp
  .hxx .in .txx
CMake Error: CMake can not determine linker language for target: v_repExtRosInterface
CMake Error: Cannot determine link language for target "v_repExtRosInterface".
-- Generating done
-- Build files have been written to: /home/vince/catkin_ws/build
Invoking "cmake" failed
but if I run it the second time, it starts compiling it, compiles everything else, except the ROS interface:
Yes, you need to install the catkin tools, then you'll be able to use catkin build.
vakker
Post by vakker »
If I try to install ros-kinetic-catkin it says:
Reading package lists... Done
Building dependency tree
Reading state information... Done
ros-kinetic-catkin is already the newest version (0.7.1-0xenial-20160318-144042-0700).
0 to upgrade, 0 to newly install, 0 to remove and 17 not to upgrade.
but I installed it anyway by:
sudo apt-get install python-catkin-tools
Then I issued catkin build, and it gave:
The build space at '/home/vakker/catkin_ws/build' was previously built by 'catkin_make'. Please remove the build space or pick a different build space.
So what should I do?
Did you try to clear the workspace? This is what the message is suggesting. Have a look at the commands I previously posted for a clean build.
vakker
Post by vakker »
Yes, but if I clean the workspace, and run the things again, then it will still complain, since the workspace was made by catkin_make, so I tried using catkin build only, but it also gave errors:
Workspace configuration appears valid.
[build] Found '8' packages in 0.0 seconds.
Starting  >>> ros_bubble_rob2
Starting  >>> vrep_common
Starting  >>> vrep_joy
Starting  >>> vrep_ros_interface
Finished  <<< ros_bubble_rob2                          [ 14.8 seconds ]
Finished  <<< vrep_joy                                 [ 14.7 seconds ]
Starting  >>> vrep_skeleton_msg_and_srv
Finished  <<< vrep_skeleton_msg_and_srv                [ 11.1 seconds ]
Starting  >>> vrep_plugin_skeleton
______________________________________________________________________________________________________________________________________________________________________________
Errors     << vrep_plugin_skeleton:make /home/vince/catkin_ws/logs/vrep_plugin_skeleton/build.make.000.log
/usr/bin/ld: cannot find -lroslib
/usr/bin/ld: cannot find -lrosconsole
/usr/bin/ld: cannot find -lrostime
/usr/bin/ld: cannot find -lrospack
/usr/bin/ld: cannot find -lroscpp_serialization
collect2: error: ld returned 1 exit status
make[2]: *** [/home/vince/catkin_ws/devel/.private/vrep_plugin_skeleton/lib/libv_repExtRosSkeleton.so] Error 1
make[1]: *** [CMakeFiles/v_repExtRosSkeleton.dir/all] Error 2
make: *** [all] Error 2
cd /home/vince/catkin_ws/build/vrep_plugin_skeleton; catkin build --get-env vrep_plugin_skeleton | catkin env -si  /usr/bin/make --jobserver-fds=6,7 -j; cd -
Failed     << vrep_plugin_skeleton:make                [ Exited with code 2 ]
Failed    <<< vrep_plugin_skeleton                     [ 19.0 seconds ]
Abandoned <<< ros_bubble_rob                           [ Unrelated job failed ]
Abandoned <<< vrep_plugin                              [ Unrelated job failed ]
Finished  <<< vrep_common                              [ 1 minute and 28.4 seconds ]
Errors     << vrep_ros_interface:make /home/vince/catkin_ws/logs/vrep_ros_interface/build.make.000.log
/usr/bin/ld: cannot find -ltf
/usr/bin/ld: cannot find -limage_transport
make[2]: *** [/home/vince/catkin_ws/devel/.private/vrep_ros_interface/lib/libv_repExtRosInterface.so] Error 1
make[1]: *** [CMakeFiles/v_repExtRosInterface.dir/all] Error 2
cd /home/vince/catkin_ws/build/vrep_ros_interface; catkin build --get-env vrep_ros_interface | catkin env -si  /usr/bin/make --jobserver-fds=6,7 -j; cd -
Failed     << vrep_ros_interface:make                  [ Exited with code 2 ]
Failed    <<< vrep_ros_interface                       [ 2 minutes and 55.4 seconds ]
[build] Summary: 4 of 8 packages succeeded.
[build]   Ignored:   None.
[build]   Warnings:  None.
[build]   Abandoned: 2 packages were abandoned.
[build]   Failed:    2 packages failed.
[build] Runtime: 2 minutes and 56.1 seconds total.
Also, I think later ROS would complain that my workspace was built by catkin and not catkin_make.
Ok, I didn't realize you are using kinetic. So you will have to add following to most CMakeLists.txt files:
link_directories("/opt/ros/fuerte/lib")
link_directories("/opt/ros/groovy/lib")
link_directories("/opt/ros/hydro/lib")
link_directories("/opt/ros/indigo/lib")
link_directories("/opt/ros/jade/lib")
link_directories("/opt/ros/kinetic/lib")
prisca
Post by prisca »
Hi, I've ran into the same issue, using Ubuntu 16.04, ROS Kinetic and V-REP PRO EDU 3.3.2.
I've managed to build V-REP packages with catkin build (from package python-catkin-tools) in a dedicated workspace.
However I have linking warnings in cmake.
With vrep_plugin:
CMake Warning at /opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:166 (message):
catkin_package() DEPENDS on 'roslib' but neither 'roslib_INCLUDE_DIRS' nor
'roslib_LIBRARIES' is defined.
/opt/ros/kinetic/share/catkin/cmake/catkin_package.cmake:102 (_catkin_package)
CMakeLists.txt:8 (catkin_package)
with vrep_plugin_skeleton:
with vrep_ros_interface:
catkin_package() DEPENDS on 'brics_actuator' but neither
'brics_actuator_INCLUDE_DIRS' nor 'brics_actuator_LIBRARIES' is defined.
CMakeLists.txt:12 (catkin_package)
catkin_package() DEPENDS on 'control_msgs' but neither
'control_msgs_INCLUDE_DIRS' nor 'control_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'diagnostic_msgs' but neither
'diagnostic_msgs_INCLUDE_DIRS' nor 'diagnostic_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'map_msgs' but neither 'map_msgs_INCLUDE_DIRS'
nor 'map_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'nav_msgs' but neither 'nav_msgs_INCLUDE_DIRS'
nor 'nav_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'pcl_msgs' but neither 'pcl_msgs_INCLUDE_DIRS'
nor 'pcl_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'shape_msgs' but neither
'shape_msgs_INCLUDE_DIRS' nor 'shape_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'tf2_geometry_msgs' but neither
'tf2_geometry_msgs_INCLUDE_DIRS' nor 'tf2_geometry_msgs_LIBRARIES' is
defined.
catkin_package() DEPENDS on 'tf2_sensor_msgs' but neither
'tf2_sensor_msgs_INCLUDE_DIRS' nor 'tf2_sensor_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'trajectory_msgs' but neither
'trajectory_msgs_INCLUDE_DIRS' nor 'trajectory_msgs_LIBRARIES' is defined.
catkin_package() DEPENDS on 'visualization_msgs' but neither
'visualization_msgs_INCLUDE_DIRS' nor 'visualization_msgs_LIBRARIES' is
defined.
Can you please tell me how to solve? Thanks.
prisca
Post by prisca »
OK, I found out that I just needed to set those variables in packages CMakeLists.txt like this:
set(roslib_LIBRARIES "/opt/ros/kinetic/lib/roslib")
Also before building, I had to compile and install globally brics_actuator from Github, because it's not present in Kinetic.
The variables setting is weird, it's like catkin build is not able to recognize /opt/ros/kinetic even if I did the directory linking you suggested.
...Plus, it's still not working completely: in the tutorial here I'm not able to see the sensor data with this command:
rosrun image_view image_view image:=/visionSensorData
and one of the little robots in controlTypeExamples.ttt is not able to find its plugin.
Is it possible to make V-REP fully work with ROS Kinetic, or it'd be better to switch back to Indigo for the time being?
