The physics engine currently selected is not supported
Re: The physics engine currently selected is not supported
are you also running V-REP on Win7? Do the plugins load correctly when you launch it via the launcher or by double-clicking a V-REP scene? Finally, have you installed the VC redistribuable packages?
What happens if you simply copy the V-REP PRO EDU folder to another location, and try to launch it there from the command line?
It might also be that you need to be specifically in the V-REP folder when launching it.
So:
C:\Program Files (x86)\V-REP3>V-REP_PRO_EDU\vrep.exe
might not work, but this should work:
C:\Program Files (x86)\V-REP3\V-REP_PRO_EDU>vrep.exe
cetigo
Post by cetigo »
Hi, I'm running V-Rep from Win 10, the plugins load correctly when launching from the link or when double clicking the vrep.exe.
I tried your solutions and it works when I'm launching it from the directory where it is installed. It doesn't work if I launch it from another location.
Thanks for the help!
FrankVeen
Post by FrankVeen »
Hi Coppelia,
I am having the same issue but I would like to run vrep from another directory so that a genetic algorithm plugin will store files in specific directories. I would like to do this so that I can run vrep multiple times in parallel. In both windows and linux I am however unable to load the physics plugins and I get the same error messages as cetigo mentioned. Vrep works fine when I run it from the v-rep directoy. Is there any possibility of running v-rep from another directory? Or do you have any advice on a workaround?
Thank in advance!
Cheers, Frank
Hello Frank,
the best would probably to start V-REP from its installation folder and be able to specify a path when storing your files.
If you can't do this for whatever reason, then you can recompile the main client application that you can find in programming/v_repClientApplication. But before you recompile it, add following at the beginning of function main in file main.cpp:
int main(int argc, char* argv[])
#ifdef WIN_VREP
    // Set the current path same as the application path
    char basePath[2048];
    _fullpath(basePath,argv[0],sizeof(basePath));
    std::string p(basePath);
    p.erase(p.begin()+p.find_last_of('\\')+1,p.end());
    printf(p.c_str());
    QDir::setCurrent(p.c_str());
#endif
This sets the current directory same as the application's directory.
