About using MATLAB to get joint angle and set joint angle
youngsea
Post by youngsea »
Hi~
I use other devices to control the robot in V-rep.Now I want to get the data of the joint angle changing with time during the simulation.
And then I want to control the robot using the joint angle obtained by the above method.
Which remote API functions (Matlab) can do that?simxGetJointPosition and simxSetJointPosition?
youngsea
Re: About using MATLAB to get joint angle and set joint angle
Post by youngsea »
I write a matlab function as follows,
function baxter()
	disp('Program started');
	% vrep=remApi('remoteApi','extApi.h'); % using the header (requires a compiler)
	vrep=remApi('remoteApi'); % using the prototype file (remoteApiProto.m)
	vrep.simxFinish(-1); % just in case, close all opened connections
	clientID=vrep.simxStart('127.0.0.1',19999,true,true,5000,5);
	if (clientID>-1)
		disp('Connected to remote API server');
         %-- Handle of the right arm joint
        rightArmjoint1=vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint1',vrep.simx_opmode_blocking);
        rightArmjoint2=vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint2',vrep.simx_opmode_blocking);
         %-- Handle of the left arm joint
        leftArmjoint1=vrep.simxGetObjectHandle(clientID,'Baxter_leftArm_joint1',vrep.simx_opmode_blocking);
        leftArmjoint2=vrep.simxGetObjectHandle(clientID,'Baxter_leftArm_joint2',vrep.simx_opmode_blocking);
        %Now read right arm joint angle
         [res,r1angle]=vrep.simxGetJointPosition(clientID,rightArmjoint1,vrep.simx_opmode_blocking);
         %to test
          r1angle
         [res,r2angle]=vrep.simxGetJointPosition(clientID,rightArmjoint2,vrep.simx_opmode_blocking);
         r2angle
          %Now read left arm joint angle
         [res,l1angle]=vrep.simxGetJointPosition(clientID,leftArmjoint1,vrep.simx_opmode_blocking);
         [res,l2angle]=vrep.simxGetJointPosition(clientID,leftArmjoint2,vrep.simx_opmode_blocking);
		% Before closing the connection to V-REP, make sure that the last command sent out had time to arrive. You can guarantee this with (for example):
		vrep.simxGetPingTime(clientID);
		% Now close the connection to V-REP:
		vrep.simxFinish(clientID);
		disp('Failed connecting to remote API server');
	vrep.delete(); % call the destructor!
	disp('Program ended');
And then run the demo Baxter and the Matlab fuction,the result as follows,
r1angle =
43
r2angle =
43
While I use the code as follow,
[res,r1angle]=vrep.simxGetJointPosition(clientID,rightArmjoint1,vrep.simx_opmode_streaming);
         while res ~= 0
           [res,r1angle]=vrep.simxGetJointPosition(clientID,rightArmjoint1,vrep.simx_opmode_buffer);
           r1angle
The result is,
r1angle =
43
r1angle =
43
This value will not change or end.
How can I read the date in a certain sampling time?
Thanks!
youngsea
Post by youngsea »
The question about using MATLAB to get joint angle has been solved.The main code of Matlab is shown below
   if (clientID>-1)
       % get handle for Baxter_rightArm_joint1
      [res,handle_rigArmjoint1] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint1',vrep.simx_opmode_oneshot_wait);
        while(vrep.simxGetConnectionId(clientID) ~= -1),  % while v-rep connection is still active
         t = vrep.simxGetLastCmdTime(clientID) / 1000.0;  % get current simulation time
         if (t > 60) break;
         end  % stop after t = 60 seconds
         [res,r1angle]=vrep.simxGetJointPosition(clientID,handle_rigArmjoint1,vrep.simx_opmode_oneshot_wait);
         r1= [r1 r1angle];
       fid = fopen('r.txt','wt');
       fprintf(fid,'%g\n',r);
       fclose(fid);
And then I write another M file to set joint angle.Run the V-REP and MATLAB,the robot in another scene can move.However,when the robot moves, its jitter is too great.How can I improve it~Thanks~
      %read the joint angle data from 'r.txt'
      jointValue=load('r.txt');   %A matrix of 7 x 150.Each column vector recorded the changes of each joint Angle
   if (clientID>-1)
      [res,handle_rigArmjoint2] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint2',vrep.simx_opmode_oneshot_wait);
      [res,handle_rigArmjoint3] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint3',vrep.simx_opmode_oneshot_wait);
      [res,handle_rigArmjoint4] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint4',vrep.simx_opmode_oneshot_wait);
      [res,handle_rigArmjoint5] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint5',vrep.simx_opmode_oneshot_wait);
      [res,handle_rigArmjoint6] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint6',vrep.simx_opmode_oneshot_wait);
      [res,handle_rigArmjoint7] = vrep.simxGetObjectHandle(clientID,'Baxter_rightArm_joint7',vrep.simx_opmode_oneshot_wait);
      %Set the position of every joint
          if (t > 60) break;
          for i=1:100
         vrep.simxPauseCommunication(clientID,1);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint1,jointValue(i,1),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint2,jointValue(i,2),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint3,jointValue(i,3),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint4,jointValue(i,4),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint5,jointValue(i,5),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint6,jointValue(i,6),vrep.simx_opmode_oneshot);
         vrep.simxSetJointTargetPosition(clientID,handle_rigArmjoint7,jointValue(i,7),vrep.simx_opmode_oneshot);
         vrep.simxPauseCommunication(clientID,0);
in the first step, you are reading the joint values from V-REP. You are not using the data streaming, so things might get quite slow (for now you are only reading one joint, but as soon as you are trying to read several joints, things will get slow with the blocking method).
When you apply joints, you almost apply them at once, you don't have any timing: your loop that starts with
for i=1:100
will almost instantaneously execute. You need to put some waits in there, or check the V-REP side timing to know if you are ready to send the next joint positions.
youngsea
Post by youngsea »
Using the Matlab function pause(),the results have been improved.And I will I will follow your advice to test it.
I have a questions about using two remote API in one child script.
simExtRemoteApiStart(19999) is used to connect a C++ application,while simExtRemoteApiStart(19998) is used to connect Matlab.
Can it work in the same script?
Thank you very much!
simExtRemoteApiStart is used to create a temporary remote API server sevice. Any type of remote API client can connect to that server service (i.e. C/C++/Java/Matlab/Python/Octave/Lua/Urbi).
You can start almost as many remote API server services as you wish, but you need to make sure to start them on a different port, and that those ports are not used by other applications.
