passing parameters
IRIIWU
passing parameters
Post by IRIIWU »
Hey Coppelia,
How would you pass some variables from one child script to another? for eg I have a table from one child script which I want to access from another. Any help would be great.
Re: passing parameters
you have several ways of doing this. You can call simSetScriptVariable, simCallScriptFunction, or you can also use following method:
You can have objectA write a value into objectB with:
local myVariable={}
myVariable.openGripper=true
simWriteCustomDataBlock(objectB,'myData',simPackTable(myVariable))
and check on a regular base in objectB that value with:
local data=simReadCustomDataBlock(objectB,'myData')
if data then
    local myVariable=simUnpackTable(data)
    if myVariable.openGripper then
