python / bluezero
Justus
python / bluezero
Post by Justus »
I'm trying my hands on the BlueZero interface, using Python 3.7 x64 on Win10 and V-REP PRO 3.5.0 (rev4).
Starting with a very basic test: I can load remoteapi.dll just fine (using the remoteapi.dll in path: programming\remoteApiBindings\lib\lib\Windows\64Bit)
from ctypes import *
libc=CDLL('remoteApi')
But b0.dll doesn't import (using b0.dll in the V-REP root folder):
libc=CDLL('b0')
  File "<input>", line 1, in <module>
  File "(my python path)\lib\ctypes\__init__.py", line 356, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: [WinError 126] The specified module could not be found
Any suggestions on how to load b0.dll?
Regards,
Justus
Re: python / bluezero
Hello Justus, this is still work-in-progress, but following works on Python 2.x with the latest B0 library (tested on Windows):
File b0.py:
import platform
import struct
import sys
import os
import ctypes as ct
libb0 = None
prefix, suffix = 'lib', '.so'
if platform.system() in ('cli', 'Windows'):
    prefix, suffix = '', '.dll'
if platform.system() in ('Darwin', ):
    suffix = '.dylib'
for path in ('.', 'build', '../../build'):
    fullpath = os.path.join(os.path.dirname(__file__), path)
    if not os.path.isdir(fullpath): continue
    libb0_fullpath = os.path.join(fullpath, '%sb0%s' % (prefix, suffix))
    if os.path.exists(libb0_fullpath):
        libb0 = ct.CDLL(libb0_fullpath)
        break
if libb0 is None:
    raise RuntimeError('%sb0%s not found' % (prefix, suffix))
def _(n, ret, *args):
    # perform encoding/decoding for char* argument (use str to enable conversion)
    def _enc(v, t): return v.encode('ascii') if t == str else v
    def _dec(v, t): return v.decode('ascii') if t == str else v
    def _wrap(t): return ct.c_char_p if t == str else t
    # unwrapped CFUNCTYPE: (prefixed with _)
    globals()['_' + n] = ct.CFUNCTYPE(_wrap(ret), *[_wrap(arg) for arg in args])((n, libb0))
    # wrapped CFUNCTYPE: (performs string encoding/decoding)
    globals()[n] = lambda *args2: _dec(globals()['_' + n](*[_enc(arg, t) for t, arg in zip(args, args2)]), ret)
_("b0_buffer_new", ct.c_void_p, ct.c_size_t)
_("b0_buffer_delete", None, ct.c_void_p)
_("b0_node_new", ct.c_void_p, str)
_("b0_node_delete", None, ct.c_void_p)
_("b0_node_init", None, ct.c_void_p)
_("b0_node_shutdown", None, ct.c_void_p)
_("b0_node_shutdown_requested", ct.c_int, ct.c_void_p)
_("b0_node_spin_once", None, ct.c_void_p)
_("b0_node_spin", None, ct.c_void_p)
_("b0_node_cleanup", None, ct.c_void_p)
_("b0_node_get_name", str, ct.c_void_p)
_("b0_node_get_state", ct.c_int, ct.c_void_p)
_("b0_node_get_context", ct.c_void_p, ct.c_void_p)
_("b0_node_hardware_time_usec", ct.c_longlong, ct.c_void_p)
_("b0_node_time_usec", ct.c_longlong, ct.c_void_p)
_("b0_node_log", None, ct.c_void_p, ct.c_int, str)
_("b0_publisher_new_ex", ct.c_void_p, ct.c_void_p, str, ct.c_int, ct.c_int)
_("b0_publisher_new", ct.c_void_p, ct.c_void_p, str)
_("b0_publisher_delete", None, ct.c_void_p)
_("b0_publisher_init", None, ct.c_void_p)
_("b0_publisher_cleanup", None, ct.c_void_p)
_("b0_publisher_spin_once", None, ct.c_void_p)
_("b0_publisher_get_topic_name", str, ct.c_void_p)
_("b0_publisher_publish", None, ct.c_void_p, ct.c_void_p, ct.c_size_t)
_("b0_publisher_log", None, ct.c_void_p, ct.c_int, str)
_("b0_subscriber_new_ex", ct.c_void_p, ct.c_void_p, str, ct.c_void_p, ct.c_int, ct.c_int)
_("b0_subscriber_new", ct.c_void_p, ct.c_void_p, str, ct.c_void_p)
_("b0_subscriber_delete", None, ct.c_void_p)
_("b0_subscriber_init", None, ct.c_void_p)
_("b0_subscriber_cleanup", None, ct.c_void_p)
_("b0_subscriber_spin_once", None, ct.c_void_p)
_("b0_subscriber_get_topic_name", str, ct.c_void_p)
_("b0_subscriber_log", None, ct.c_void_p, ct.c_int, str)
_("b0_subscriber_poll", ct.c_int, ct.c_void_p, ct.c_long)
_("b0_subscriber_read", ct.c_void_p, ct.c_void_p, ct.POINTER(ct.c_size_t))
_("b0_service_client_new_ex", ct.c_void_p, ct.c_void_p, str, ct.c_int, ct.c_int)
_("b0_service_client_new", ct.c_void_p, ct.c_void_p, str)
_("b0_service_client_delete", None, ct.c_void_p)
_("b0_service_client_init", None, ct.c_void_p)
_("b0_service_client_cleanup", None, ct.c_void_p)
_("b0_service_client_spin_once", None, ct.c_void_p)
_("b0_service_client_get_service_name", str, ct.c_void_p)
_("b0_service_client_call", ct.c_void_p, ct.c_void_p, ct.c_void_p, ct.c_size_t, ct.POINTER(ct.c_size_t))
_("b0_service_client_log", None, ct.c_void_p, ct.c_int, str)
_("b0_service_server_new_ex", ct.c_void_p, ct.c_void_p, str, ct.c_void_p, ct.c_int, ct.c_int)
_("b0_service_server_new", ct.c_void_p, ct.c_void_p, str, ct.c_void_p)
_("b0_service_server_delete", None, ct.c_void_p)
_("b0_service_server_init", None, ct.c_void_p)
_("b0_service_server_cleanup", None, ct.c_void_p)
_("b0_service_server_spin_once", None, ct.c_void_p)
_("b0_service_server_get_service_name", str, ct.c_void_p)
_("b0_service_server_log", None, ct.c_void_p, ct.c_int, str)
class Node:
    def __init__(self, name='node'):
        self._node = b0_node_new(name)
    def __del__(self):
        b0_node_delete(self._node)
    def init(self):
        b0_node_init(self._node)
    def shutdown(self):
        b0_node_shutdown(self._node)
    def shutdown_requested(self):
        return b0_node_shutdown_requested(self._node)
    def spin_once(self):
        b0_node_spin_once(self._node)
    def spin(self):
        b0_node_spin(self._node)
    def cleanup(self):
        b0_node_cleanup(self._node)
    def get_name(self):
        return b0_node_get_name(self._node)
    def get_state(self):
        return b0_node_get_state(self._node)
    def get_context(self):
        return b0_node_get_context(self._node)
    def hardware_time_usec(self):
        return b0_node_hardware_time_usec(self._node)
    def time_usec(self):
        return b0_node_time_usec(self._node)
    def log(self, level, message):
        b0_node_log(self._node, level, message)
class Publisher:
    def __init__(self, node, topic_name, managed=1, notify_graph=1):
        self._pub = b0_publisher_new_ex(node._node, topic_name, managed, notify_graph)
    def __del__(self):
        b0_publisher_delete(self._pub)
    def init(self):
        b0_publisher_init(self._pub)
    def cleanup(self):
        b0_publisher_cleanup(self._pub)
        b0_publisher_spin_once(self._pub)
    def get_topic_name(self):
        return b0_publisher_get_topic_name(self._pub)
    def publish(self, data):
        buf = ct.c_char_p(data)
        b0_publisher_publish(self._pub, buf, len(data))
        b0_publisher_log(self._pub, level, message)
class Subscriber:
    def __init__(self, node, topic_name, callback, managed=1, notify_graph=1):
        def w(data, size):
            data_bytes = bytearray(ct.cast(data, ct.POINTER(ct.c_ubyte * size)).contents)
            return callback(data_bytes)
        self._cb = ct.CFUNCTYPE(None, ct.c_void_p, ct.c_size_t)(w)
        self._sub = b0_subscriber_new_ex(node._node, topic_name, self._cb, managed, notify_graph)
    def __del__(self):
        b0_subscriber_delete(self._sub)
    def init(self):
        b0_subscriber_init(self._sub)
    def cleanup(self):
        b0_subscriber_cleanup(self._sub)
        b0_subscriber_spin_once(self._sub)
        return b0_subscriber_get_topic_name(self._sub)
        b0_subscriber_log(self._sub, level, message)
    def poll(self,timeout):
        return b0_subscriber_poll(self._sub,timeout)
    def read(self):
        outsz = ct.c_size_t()
        outbuf = b0_subscriber_read(self._sub, ct.byref(outsz))
        outarr = ct.cast(outbuf, ct.POINTER(ct.c_ubyte * outsz.value))
        rep_bytes = bytearray(outarr.contents)
        return rep_bytes
class ServiceClient:
        self._cli = b0_service_client_new_ex(node._node, topic_name, managed, notify_graph)
    def __del__(self):
        b0_service_client_delete(self._cli)
    def init(self):
        b0_service_client_init(self._cli)
    def cleanup(self):
        b0_service_client_cleanup(self._cli)
        b0_service_client_spin_once(self._cli)
    def get_service_name(self):
        return b0_service_client_get_service_name(self._cli)
    def call(self, data):
        sz = len(data)
        outbuf = b0_service_client_call(self._cli, buf, sz, ct.byref(outsz))
        return rep_bytes
        b0_service_client_log(self._cli, level, message)
class ServiceServer:
        def w(data, size, outsize):
            req_bytes = bytearray(ct.cast(data, ct.POINTER(ct.c_ubyte * size)).contents)
            resp_bytes = callback(req_bytes)
            outsize[0] = len(resp_bytes)
            outdata = b0_buffer_new(outsize[0])
            outarr = ct.cast(outdata, ct.POINTER(ct.c_ubyte * outsize[0]))
            #for i, c in enumerate(resp_str): outarr.contents[i] = ord(c)
            ct.memmove(outarr, ct.c_char_p(resp_bytes), len(resp_bytes))
            return outdata
        self._cb = ct.CFUNCTYPE(ct.c_void_p, ct.c_void_p, ct.c_size_t, ct.POINTER(ct.c_size_t))(w)
        self._srv = b0_service_server_new_ex(node._node, topic_name, self._cb, managed, notify_graph)
    def __del__(self):
        b0_service_server_delete(self._srv)
    def init(self):
        b0_service_server_init(self._srv)
    def cleanup(self):
        b0_service_server_cleanup(self._srv)
        b0_service_server_spin_once(self._srv)
        return b0_service_server_get_service_name(self._srv)
        b0_service_server_log(self._srv, level, message)
In next release there will be a b0-based remote API, that uses above and following:
File b0RemoteApi.py:
import b0
import msgpack
import random
import string
import time
class RemoteApiClient:
    def __init__(self,nodeName='b0RemoteApi_pythonClient',channelName='b0RemoteApi',inactivityToleranceInSec=60,setupSubscribersAsynchronously=False):
        self._channelName=channelName
        self._serviceCallTopic=channelName+'SerX'
        self._defaultPublisherTopic=channelName+'SubX'
        self._defaultSubscriberTopic=channelName+'PubX'
        self._nextDefaultSubscriberHandle=2
        self._nextDedicatedPublisherHandle=500
        self._nextDedicatedSubscriberHandle=1000
        self._node=b0.Node(nodeName)
        self._clientId=''.join(random.choice(string.ascii_uppercase+string.ascii_lowercase+string.digits) for _ in range(10))
        self._serviceClient=b0.ServiceClient(self._node,self._serviceCallTopic)
        self._defaultPublisher=b0.Publisher(self._node,self._defaultPublisherTopic)
        self._defaultSubscriber=b0.Subscriber(self._node,self._defaultSubscriberTopic,None) # we will poll the socket
        print('\n  Running B0 Remote API client with channel name ['+channelName+']')
        print('  make sure that: 1) the B0 resolver is running')
        print('                  2) V-REP is running the B0 Remote API server with the same channel name')
        print('  Initializing...\n')
        self._node.init()
        self._handleFunction('inactivityTolerance',[inactivityToleranceInSec],self._serviceCallTopic)
        print('\n  Connected!\n')
        self._allSubscribers={}
        self._allDedicatedPublishers={}
        self._setupSubscribersAsynchronously=setupSubscribersAsynchronously
    def __enter__(self):
        return self
    def __exit__(self,*err):
        self._pongReceived=False
        self._handleFunction('Ping',[0],self.simxDefaultSubscriber(self._pingCallback))
        while not self._pongReceived:
            self.simxSpinOnce();
        self._handleFunction('DisconnectClient',[self._clientId],self._serviceCallTopic)
        for key, value in self._allSubscribers.items():
            if value['handle']!=self._defaultSubscriber:
                value['handle'].cleanup()
        for key, value in self._allDedicatedPublishers.items():
            value.cleanup()
        self._node.cleanup()
    def _pingCallback(self,msg):
        self._pongReceived=True
    def _handleReceivedMessage(self,msg):
        msg=msgpack.unpackb(msg)
        msg[0]=msg[0].decode('ascii')
        if msg[0] in self._allSubscribers:
            cbMsg=msg[1]
            if len(cbMsg)==1:
                cbMsg.append(None)
            self._allSubscribers[msg[0]]['cb'](cbMsg)
    def _handleFunction(self,funcName,reqArgs,topic):
        if topic==self._serviceCallTopic:
            packedData=msgpack.packb([[funcName,self._clientId,topic,0],reqArgs])
            rep = msgpack.unpackb(self._serviceClient.call(packedData))
            if len(rep)==1:
                rep.append(None)
            return rep
        elif topic==self._defaultPublisherTopic:
            packedData=msgpack.packb([[funcName,self._clientId,topic,1],reqArgs])
            self._defaultPublisher.publish(packedData)
        elif topic in self._allSubscribers:
            if self._allSubscribers[topic]['handle']==self._defaultSubscriber:
                packedData=msgpack.packb([[funcName,self._clientId,topic,2],reqArgs])
                if self._setupSubscribersAsynchronously:
                else:
            else:
                packedData=msgpack.packb([[funcName,self._clientId,topic,4],reqArgs])
                else:
        elif topic in self._allDedicatedPublishers:
            packedData=msgpack.packb([[funcName,self._clientId,topic,3],reqArgs])
            self._allDedicatedPublishers[topic].publish(packedData)
        else:
            print('B0 Remote API error: invalid topic')
    def simxDefaultPublisher(self):
        return self._defaultPublisherTopic
    def simxCreatePublisher(self,dropMessages=False):
        topic=self._channelName+'Sub'+str(self._nextDedicatedPublisherHandle)+self._clientId
        self._nextDedicatedPublisherHandle=self._nextDedicatedPublisherHandle+1
        pub=b0.Publisher(self._node,topic,0,1)
        pub.init()
        self._allDedicatedPublishers[topic]=pub
        self._handleFunction('createSubscriber',[topic,dropMessages],self._serviceCallTopic)
        return topic
    def simxDefaultSubscriber(self,cb,publishInterval=1):
        topic=self._channelName+'Pub'+str(self._nextDefaultSubscriberHandle)+self._clientId
        self._nextDefaultSubscriberHandle=self._nextDefaultSubscriberHandle+1
        self._allSubscribers[topic]={}
        self._allSubscribers[topic]['handle']=self._defaultSubscriber
        self._allSubscribers[topic]['cb']=cb
        self._allSubscribers[topic]['dropMessages']=False
        channel=self._serviceCallTopic
            channel=self._defaultPublisherTopic
        self._handleFunction('setDefaultPublisherPubInterval',[topic,publishInterval],channel)
        return topic
    def simxCreateSubscriber(self,cb,publishInterval=1,dropMessages=False):
        topic=self._channelName+'Pub'+str(self._nextDedicatedSubscriberHandle)+self._clientId
        self._nextDedicatedSubscriberHandle=self._nextDedicatedSubscriberHandle+1
        sub=b0.Subscriber(self._node,topic,None,0,1)
        sub.init()
        self._allSubscribers[topic]['handle']=sub
        self._allSubscribers[topic]['dropMessages']=dropMessages
        self._handleFunction('createPublisher',[topic,publishInterval],channel)
        return topic
    def simxServiceCall(self):
        return self._serviceCallTopic
    def simxSpin(self):
        while True:
            self.simxSpinOnce()
    def simxSpinOnce(self):
        defaultSubscriberAlreadyProcessed=False
            readData=None
            if (value['handle']!=self._defaultSubscriber) or (not defaultSubscriberAlreadyProcessed):
                defaultSubscriberAlreadyProcessed=defaultSubscriberAlreadyProcessed or (value['handle']==self._defaultSubscriber)
                while value['handle'].poll(0):
                    readData=value['handle'].read()
                    if not value['dropMessages']:
                        self._handleReceivedMessage(readData)
                if value['dropMessages'] and (readData is not None):
    def simxGetTimeInMs(self):
        return self._node.hardware_time_usec()/1000;
    def simxSleep(self,durationInMs):
        time.sleep(durationInMs)
    def simxSynchronous(self,enable):
        reqArgs = [enable]
        funcName = 'Synchronous'
        self._handleFunction(funcName,reqArgs,self._serviceCallTopic)
    def simxSynchronousTrigger(self):
        reqArgs = [0]
        funcName = 'SynchronousTrigger'
        self._handleFunction(funcName,reqArgs,self._defaultPublisherTopic)
    def simxGetSimulationStepDone(self,topic):
            reqArgs = [0]
            funcName = 'GetSimulationStepDone'
            self._handleFunction(funcName,reqArgs,topic)
        else:
    def simxGetSimulationStepStarted(self,topic):
            reqArgs = [0]
            funcName = 'GetSimulationStepStarted'
        else:
    # Add your custom function here:
    def simxAuxiliaryConsoleClose(self,consoleHandle,topic):
        reqArgs = [consoleHandle]
        funcName = 'AuxiliaryConsoleClose'
        return self._handleFunction(funcName,reqArgs,topic)
    def simxAuxiliaryConsolePrint(self,consoleHandle,text,topic):
        reqArgs = [consoleHandle,text]
        funcName = 'AuxiliaryConsolePrint'
    def simxAuxiliaryConsoleOpen(self,title,maxLines,mode,position,size,textColor,backgroundColor,topic):
        reqArgs = [title,maxLines,mode,position,size,textColor,backgroundColor]
        funcName = 'AuxiliaryConsoleOpen'
    def simxAuxiliaryConsoleShow(self,consoleHandle,showState,topic):
        reqArgs = [consoleHandle,showState]
        funcName = 'AuxiliaryConsoleShow'
    def simxGetObjectHandle(self,objectName,topic):
        reqArgs = [objectName]
        funcName = 'GetObjectHandle'
    def simxAddStatusbarMessage(self,txt,topic):
        reqArgs = [txt]
        funcName = 'AddStatusbarMessage'
    def simxGetObjectPosition(self,objectHandle,refObjectHandle,topic):
        reqArgs = [objectHandle,refObjectHandle]
        funcName = 'GetObjectPosition'
    def simxStartSimulation(self,topic):
        reqArgs = []
        funcName = 'StartSimulation'
    def simxStopSimulation(self,topic):
        reqArgs = []
        funcName = 'StopSimulation'
    def simxGetVisionSensorImage(self,objectHandle,greyscale,topic):
        reqArgs = [objectHandle,greyscale]
        funcName = 'GetVisionSensorImage'
    def simxSetVisionSensorImage(self,objectHandle,greyscale,img,topic):
        reqArgs = [objectHandle,greyscale,img]
        funcName = 'SetVisionSensorImage'
    def simxAddDrawingObject_points(self,size,color,coords,topic):
        reqArgs = [size,color,coords]
        funcName = 'AddDrawingObject_points'
    def simxAddDrawingObject_spheres(self,size,color,coords,topic):
        funcName = 'AddDrawingObject_spheres'
    def simxAddDrawingObject_cubes(self,size,color,coords,topic):
        funcName = 'AddDrawingObject_cubes'
    def simxAddDrawingObject_lines(self,lineSize,color,segments,topic):
        reqArgs = [lineSize,color,segments]
        funcName = 'AddDrawingObject_lines'
    def simxAddDrawingObject_triangles(self,color,triangles,topic):
        reqArgs = [color,triangles]
        funcName = 'AddDrawingObject_triangles'
    def simxRemoveDrawingObject(self,handle,topic):
        reqArgs = [handle]
        funcName = 'RemoveDrawingObject'
    def simxCallScriptFunction(self,funcAtObjName,scriptType,arg1,arg2,arg3,arg4,topic):
        reqArgs = [funcAtObjName,scriptType,arg1,arg2,arg3,arg4]
        funcName = 'CallScriptFunction'
    def simxCheckCollision(self,entity1,entity2,topic):
        reqArgs = [entity1,entity2]
        funcName = 'CheckCollision'
    def simxGetCollisionHandle(self,name,topic):
        reqArgs = [name]
        funcName = 'GetCollisionHandle'
    def simxReadCollision(self,handle,topic):
        reqArgs = [handle]
        funcName = 'ReadCollision'
    def simxCheckDistance(self,entity1,entity2,threshold,topic):
        reqArgs = [entity1,entity2,threshold]
        funcName = 'CheckDistance'
    def simxGetDistanceHandle(self,name,topic):
        reqArgs = [name]
        funcName = 'GetDistanceHandle'
    def simxReadDistance(self,handle,topic):
        reqArgs = [handle]
        funcName = 'ReadDistance'
    def simxCheckProximitySensor(self,sensor,entity,topic):
        reqArgs = [sensor,entity]
        funcName = 'CheckProximitySensor'
    def simxReadProximitySensor(self,handle,topic):
        reqArgs = [handle]
        funcName = 'ReadProximitySensor'
    def simxCheckVisionSensor(self,sensor,entity,topic):
        funcName = 'CheckVisionSensor'
    def simxReadVisionSensor(self,handle,topic):
        reqArgs = [handle]
        funcName = 'ReadVisionSensor'
    def simxReadForceSensor(self,handle,topic):
        reqArgs = [handle]
        funcName = 'ReadForceSensor'
    def simxBreakForceSensor(self,handle,topic):
        reqArgs = [handle]
        funcName = 'BreakForceSensor'
    def simxClearFloatSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'ClearFloatSignal'
    def simxClearIntegerSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'ClearIntegerSignal'
    def simxClearStringSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'ClearStringSignal'
    def simxSetFloatSignal(self,sig,val,topic):
        reqArgs = [sig,val]
        funcName = 'SetFloatSignal'
    def simxSetIntegerSignal(self,sig,val,topic):
        reqArgs = [sig,val]
        funcName = 'SetIntegerSignal'
    def simxSetStringSignal(self,sig,val,topic):
        reqArgs = [sig,val]
        funcName = 'SetStringSignal'
    def simxGetFloatSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'GetFloatSignal'
    def simxGetIntegerSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'GetIntegerSignal'
    def simxGetStringSignal(self,sig,topic):
        reqArgs = [sig]
        funcName = 'GetStringSignal'
    #constants to be added here
There will also be a customization script on the V-REP side to handle messages (publishers, subscribers and service calls)
Justus
Post by Justus »
Thanks for the info; so I suppose it is better to wait for a next release/revision before working with the BlueZero interface?
Will it also support the shared memory feature (like the current remoteApi)?
I tried the above with Python 2.7.13 (x86-64), but I still get the same error. Workflow: install python 2.7, put the .dll in the same dir, open python.exe (console) and run
libc=CDLL('b0')
Above works like a charm with remoteapi.dll
Probably something simple, do you have any clue what might go wrong? Are there any dependencies in the DLL that could be an issue, or a 32/64bit thing?
Regards,
Justus
<edit> Also checked both remoteApi.dll and b0.dll with Dependency Walker, both dll's report many missing dependencies.
Yes, there are several dependencies. On Windows typically, you need following items too, next to b0.dll:
  • boost_chrono_vc140-mt-1_62.dll
  • boost_system_vc140-mt-1_62.dll
  • boost_thread_vc140-mt-1_62.dll
  • libzmq.dll
The b0.py and b0RemoteApi.py code in my previous post was updated. Now it should also work With Python 3.X
Justus
Post by Justus »
When running b0.py in the V-REP folder there is no missing DLL issue anymore (import b0 is succesful). However, a new error comes up (using Python 2.7, vanilla installation).
  File "b0remoteapi.py", line 1, in <module>
    import b0
  File "C:\Program Files\V-REP3\V-REP_PRO\b0.py", line 71, in <module>
  File "C:\Program Files\V-REP3\V-REP_PRO\b0.py", line 33, in _
AttributeError: function 'b0_subscriber_poll' not found
Just to let you know. (I'll continue using the standard remoteApi.dll for now.)
It seems b0_subscriber_poll has been recently added to the python bindings (see commit 77bfd9f9).
So you'll need to get the latest source code from the bluezero git repository.
xuehonghu
Post by xuehonghu »
Hey, I wonder where did you guys get b0.dll or other relevant .dll , under the folder C:\Program Files\V-REP3\V-REP_PRO_EDU\programming\..... I failed to find b0.dll
most dlls are located where the V-REP executable is located. Or you can rebuild them.
