Importing and visualizing pointcloud
Tiber
Post by Tiber »
Hi,I am a newbie using V-REP and I’m trying to subscribe a ros topic of type sensor_msg/Pointcloud2 and show its content into a pointcloud object.But I can’t get the function sim.insertPointsIntoPointCloud working.The errors I get are “One of the function's argument type is not correct” and “[string -unknown location]:?: ros_callback__sensor_msgs__PointCloud2: simCallScriptFunctionEx: error (pointcloudMessage_callback)”.
The code I am using:
function sysCall_init()
    size=1
    col={100,100,100}
    pc=sim.createPointCloud(0.02,20,0,size)
    sub=simROS.subscribe('/camera/depth_registered/points', 'sensor_msgs/PointCloud2', 'pointcloudMessage_callback')
    simROS.subscriberTreatUInt8ArrayAsString(sub)
function pointcloudMessage_callback(pts)
    local points={}
    local num=pts.width*pts.height
    for i=0,num-1 do
        table.insert(points,pts.data[3*i])
        table.insert(points,pts.data[3*i+1])
        table.insert(points,pts.data[3*i+2])
    sim.insertPointsIntoPointCloud(pc,0,ponits,col,nil)
Hope someone can help me.
Thank you in advance.
Sincerely,
Tiber
gendibal784
Re: Importing and visualizing pointcloud
Post by gendibal784 »
It seems to me that you don't define the variable nil on your code
Perhaps it's the reason because of the error say [string -unknown location]
Tiber
Post by Tiber »
I think nil is not a variable but a type represents a case of "non-value".Am I wrong?
you wrote ponits, but it should be points...
Tiber
Post by Tiber »
Thanks a lot! But I realized this was not where the main problem lies. The main reason is that I got the data type wrong.The point data of type sensor_msgs/PointCloud2 is stored as a Uint8 array and every four elements represent a component of the coordinates of a point. And the function simROS.subscriberTreatUInt8ArrayAsString treats uint8 arrays as string, so the data obtained by the subscriber should be converted to the Float type to obtain the coordinate information and to the Uint8 type to obtain the RGB information separately.
The code I am using now:
    size=1
    pointcloud=sim.getObjectHandle('pointcloud')
    depthCam=sim.getObjectHandle('kinect_depth')
    sim.setObjectMatrix(pc,-1,sim.getObjectMatrix(depthCam,-1))
    sim.removePointsFromPointCloud(pc,0,nil,0)
    local start=sim.getSystemTimeInMs(-2)
    local points={}
    local col={}
    tables=sim.unpackFloatTable(pts.data,0,0,0)
    tables1=sim.unpackUInt8Table(pts.data,0,0,0)
    local unpack=sim.getSystemTimeInMs(-2)
    for  i=0,num-1 do
        if(tables[8*i+1]==tables[8*i+1]) then
           table.insert(col,tables1[32*i+19])
           table.insert(col,tables1[32*i+18])
           table.insert(col,tables1[32*i+17])
           table.insert(points,-tables[8*i+1])
           table.insert(points,-tables[8*i+2])
           table.insert(points,tables[8*i+3])
    local extract=sim.getSystemTimeInMs(-2)
    sim.insertPointsIntoPointCloud(pc,3,points,col,nil)
    local insert=sim.getSystemTimeInMs(-2)
    time1=unpack-start
    time2=extract-unpack
    time3=insert-extract
    dlgHandle=nil
    local txt='unpack_time='..time1.."ms    extract_time="..time2.."ms    insert_time="..time3.."ms"
    dlgHandle=sim.displayDialog('info',txt,sim.dlgstyle_message,false)
    sim.switchThread()
Hope it can help others.
And I didn't take into account its efficiency. If you have a better solution, welcome to share with me.
Thank you!
Maybe the following API function can help: sim.transformBuffer
