simVision problem
lyz
simVision problem
Post by lyz »
I am using CoppeliaSim API to publish kinect depth data. Previously, when I used vrep 3.6.2, image processing was done through the Image processing and triggering to output depth image in GUI. Equivalent to " Work image to output depth image" in Image processing and triggering in vrep. Because the image in vrep has an inverted relationship with the image displayed by rviz, I need to use vertical processing for the image and output depth image.
Since Image processing and triggering function in CoppeliaSim is written in code instead of GUI setting in vrep, the laser and vision model in vrep I built cannot be used, so I need to write image processing code instead, But I noticed that the function was missing: workImg to Depth image in CoppeliaSim.(http://www.coppeliarobotics.com/helpFil ... essing.htm)
Thank you in advance.
Sincerely,
lyz
Re: simVision problem
Hello Lyz,
indeed, that was removed, since we believed that it doesn't really make sense to overwrite the depth buffer of a vision sensor.
In your case, a workaround would be to transform the depth map via sim.transformImage:
    local depthBuff=sim.getVisionSensorDepthBuffer(inData.handle+sim.handleflag_codedstring)
    sim.transformImage(depthBuff,inData.resolution,1+4)
    -- here you could publish your depth buffer which has been flipped vertically
But in next revision or release, you'll find simVision.workImgToSensorDepthMap too.
lyz
Post by lyz »
Okay, Many thanks! It really works.
Hello again,
rev3 of release V4.0.0 (available for download now) introduces the missing filter component simVision.workImgToSensorDepthMap
lyz
Post by lyz »
Okay, thanks a lot!
