Mathematic function on LuaScript
aven
Post by aven »
Good morning,
I would like to create a math function (e.g. a sawtooth) in a LuaScript in order to plot it in another program. Is there a way to fix it? I read the section 6.6 at the manual,http://www.lua.org/manual/5.2/manual.html#6.6, but I did not find the solution.
Thank you
Re: Mathematic function on LuaScript
Not sure I understand what you are looking for.
How about this:
> function math.saw(x) return math.fmod(x,1) end
> for x=0,3,0.2 do print(x..'\t'..math.saw(x)) end
0	0
0.2	0.2
0.4	0.4
0.6	0.6
0.8	0.8
1	0
1.2	0.2
1.4	0.4
1.6	0.6
1.8	0.8
2	1
2.2	0.2
2.4	0.4
2.6	0.6
2.8	0.8
aven
Post by aven »
fferri wrote: 25 Mar 2020, 12:20 Not sure I understand what you are looking for.
How about this:
0	0
0.2	0.2
0.4	0.4
0.6	0.6
0.8	0.8
1	0
1.2	0.2
1.4	0.4
1.6	0.6
1.8	0.8
2	1
2.2	0.2
2.4	0.4
2.6	0.6
2.8	0.8
Yes, it seems something like I need. Where may I find info about
math.saw()
and
math.fmod()
math.saw is the function I just defined.
math.modf is described in the link you posted earlier.
CoppeliaSim manual has a Lua crash course, and there are more learning resources on the Lua website.
aven
Post by aven »
fferri wrote: 25 Mar 2020, 12:59 math.saw is the function I just defined.
You're right, thank you. It works fine.
