How to control the robot to maintain a stable posture?
Shaoxiang Wang
Post by Shaoxiang Wang »
In the initial state I have adjusted the joint angle of the robot. Make the end of the manipulator face down. But when the manipulator moves, he cannot maintain a stable posture. It is possible to make the grasped object face the sky. How can he keep his posture unchanged and relatively stable?
Should I adjust the direction of Dummy, I don’t know?
The end of the robot moves along the path I have set. There is no dummy in the path, only the starting point and the ending point.
Image start position
Image during moving
best regards
shaoxiang
Re: How to control the robot to maintain a stable posture?
How are you generating the motion?
Are you using sim.generateIkPath?
Shaoxiang Wang
I used sim.getPositionOnPath, sim.getOrientationOnPath, sim.setObjectPosition, sim.setObjectOrientation.
Here is my code.
    -- do some initialization here
-- Get handles and postions of dummies
    tip = sim.getObjectHandle("tip")
    ownHandle = sim.getObjectHandle("Target")
    startPath1=sim.getObjectHandle("Path1_1")
    startPath2=sim.getObjectHandle("Path1_2")
    mittelPath1=sim.getObjectHandle("Path2_1")
    mittelPath2=sim.getObjectHandle("Path2_2")
    endPath1=sim.getObjectHandle("Path3_1")
    endPath2=sim.getObjectHandle("Path3_2")
    pathLength1=sim.getPathLength(startPath1)
    pathLength2=sim.getPathLength(startPath2)
    pathLength3=sim.getPathLength(mittelPath1)
    pathLength4=sim.getPathLength(mittelPath2)
    pathLength5=sim.getPathLength(endPath1)
    pathLength6=sim.getPathLength(endPath2)
    speed=0.02 -- end-effector velocity in m/s
    sim.setUserParameter(ownHandle,'@enable','')
    timestep=sim.getSimulationTimeStep() -- in s
    currentPositionRelative1=0
    currentPositionRelative2=0
    currentPositionRelative3=0
    currentPositionRelative4=0
    currentPositionRelative5=0
    currentPositionRelative6=0
    moveForward=true
    epsilon1=0.01
    epsilon2=0.01
    epsilon3=0.01
    epsilon4=0.01
    epsilon5=0.01
    epsilon6=0.01
function sysCall_threadmain()
    -- Put some initialization code here
    slowerWork=sim.getStringSignal("slowerWork")
    if slowerWork=="1" then
        slowerWork=true
        slowerWork=false
    -- path1
    if not slowerWork then
        pathAdvanceAbsolute=speed*timestep -- in m
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength1
        if currentPositionRelative1 < 1-epsilon1 and moveForward then
            currentPositionRelative1=currentPositionRelative1+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(startPath1,currentPositionRelative1)
            pathOrientation=sim.getOrientationOnPath(startPath1,currentPositionRelative1)
            objectPositionIsSet = sim.setObjectPosition(ownHandle,-1,pathPosition)
            objectOrientationIsSet = sim.setObjectOrientation(ownHandle,-1,pathOrientation)
        pathAdvanceAbsolute=0.2*speed*timestep -- in m
    -- path2
    if currentPositionRelative1 >= 1-epsilon1 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength2
        if currentPositionRelative2 < 1-epsilon2 and moveForward then
            currentPositionRelative2=currentPositionRelative2+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(startPath2,currentPositionRelative2)
            pathOrientation=sim.getOrientationOnPath(startPath2,currentPositionRelative2)
    -- path3
    if currentPositionRelative2 >= 1-epsilon2 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength3
        if currentPositionRelative3 < 1-epsilon3 and moveForward then
            currentPositionRelative3=currentPositionRelative3+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(mittelPath1,currentPositionRelative3)
            pathOrientation=sim.getOrientationOnPath(mittelPath1,currentPositionRelative3)
    -- path4
    if currentPositionRelative3 >= 1-epsilon3 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength4
        if currentPositionRelative4 < 1-epsilon4 and moveForward then
            currentPositionRelative4=currentPositionRelative3+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(endPath1,currentPositionRelative4)
            pathOrientation=sim.getOrientationOnPath(endPath1,currentPositionRelative4)
            currentPositionRelative4=currentPositionRelative4+pathAdvanceRelative
    -- path5
    if currentPositionRelative4 >= 1-epsilon4 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength5
        if currentPositionRelative5 < 1-epsilon5 and moveForward then
            currentPositionRelative5=currentPositionRelative5+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(endPath2,currentPositionRelative5)
            pathOrientation=sim.getOrientationOnPath(endPath2,currentPositionRelative5)
    -- path6
    if currentPositionRelative5 >= 1-epsilon5 then
        pathAdvanceRelative=pathAdvanceAbsolute/pathLength6
        if currentPositionRelative6 < 1-epsilon6 and moveForward then
            currentPositionRelative6=currentPositionRelative6+pathAdvanceRelative
            pathPosition=sim.getPositionOnPath(mittelPath2,currentPositionRelative6)
            pathOrientation=sim.getOrientationOnPath(mittelPath2,currentPositionRelative6)
    if currentPositionRelative6 >= 1-epsilon6 then
function sysCall_cleanup()
    -- Put some clean-up code here
-- See the user manual or the available code snippets for additional callback functions and details
is the orientation of the path control point correct?
Shaoxiang Wang
Thanks a lot for your tips! I adjust the orientation of point in the path. Now it is better!
We can see ,the Z axis (blue axis)of TargetDummy face ground. But the tip(another blue axis) don't follow it. I don't know why .
Made a quick test using these functions and it seems to work as expected:
function sysCall_init()
    Path=sim.getObjectHandle('Path')
    manipSphere=sim.getObjectHandle('redundantRob_manipSphere')
function sysCall_actuation()
    local t=math.fmod(sim.getSimulationTime()*0.1,1)
    local p=sim.getPositionOnPath(Path,t)
    local o=sim.getOrientationOnPath(Path,t)
    sim.setObjectPosition(manipSphere,-1,p)
    sim.setObjectOrientation(manipSphere,-1,o)
make sure IK is not failing and the calculation includes alpha beta gamma angles.
also: you are using a damped resolution method (DLS): it will take more iterations to converge to the desired end-effector position/orientation. Either reduce the damping factor, or use a non-damped resolution method (i.e. pseudo-inverse)
Shaoxiang Wang
Thank you very much! Now it works well! Thank!
