Tasks sequence
Leizah
Tasks sequence
Post by Leizah »
I got a Bill on path model and a UR10 robot and I would like to develop a sequence of tasks that involve both the models.
The Bill model stops when it has followed the 60% of its path, then it sends an integer signal to start the movement of the robot.
I was able to get this using the following code:
Bill's child script:
if currentPosOnPath>pathL*0.59 and walkingDir>0 then
   sim.setIntegerSignal('Human_TP',1)
UR10's child script
Robot_start=sim.waitForSignal('Human_TP')
if Robot_Start then
        sim.setJointTargetVelocity(simJoints[1],maxIkVel[1])
        sim.setJointTargetVelocity(simJoints[2],maxIkVel[1])
        sim.setJointTargetVelocity(simJoints[3],maxIkVel[1])
        sim.setJointTargetVelocity(simJoints[4],maxIkVel[1])
        sim.setJointTargetVelocity(simJoints[5],maxIkVel[1])
        sim.setJointTargetVelocity(simJoints[6],maxIkVel[1])
        moveToConfig_viaFK(maxConfVel,maxConfAccel,maxConfJerk,initConf,data)
        moveToPose_viaIK(maxIkVel,maxIkAccel,maxIkJerk,Target_1,data)
        moveToPose_viaIK(maxIkVel,maxIkAccel,maxIkJerk,Target_2,data)
        moveToPose_viaIK(maxIkVel,maxIkAccel,maxIkJerk,Target_3,data)
        moveToPose_viaIK(maxIkVel,maxIkAccel,maxIkJerk,Target_4,data)
This works fine, but I'm not able to stop the Bill model until the robot ends his task.
I tried creating a new integer signal into the robot code as follows:
Tip_pos=sim.getObjectpose(simTip,-1)
if Tip_pos>Target_3 then
  sim.setIntegerSignal('Robot_Finish',2)
But this solution doesn't work.
When Bill reaches the 60% of the path, the 'Human_TP' signal is sent to the robot, which starts its movement, but the Bill model doesn't stop, he continues to move.
In order to be clear, this is the sequence that I would like to get:
[*]1 - Bill walks on path
The robot is not moving
[*]2 - Bill reaches the 60% of the path, sends the signal and stops.
The robot starts moving
[*]3 - Bill stays at the 60% of the path
The robot performs its task
[*]4 - The robot ends its movement and sends a signal to let Bill move
Bill restarts his path
Right now, I was able to achieve the first 2 points, but I didn't figure out how to make Bill stop once he sends its signal.
I cannot set a time-related stop (using a wait command), because I don't know how much time the robot needs to complete its task, so I've tried with a sim.waitForSignal command, but I doesn't work.
Have you any suggestion about that issue?
Re: Tasks sequence
make sure that both items/models use threaded scripts. Then it is as simple as doing:
-- Model 1:
function sysCall_init()
    corout=coroutine.create(coroutineMain)
function sysCall_actuation()
    if coroutine.status(corout)~='dead' then
        local ok,errorMsg=coroutine.resume(corout)
        if errorMsg then
            error(debug.traceback(corout,errorMsg),2)
function coroutineMain()
    -- thread1, do task1
    sim.setInt32Signal("syncSignal",1)
    while sim.getInt32Signal("syncSignal")==1 do
        sim.switchThread()
    -- thread1, do task2
    local s=sim.getInt32Signal("syncSignal")+1
    sim.setInt32Signal("syncSignal",s)
    while sim.getInt32Signal("syncSignal")==s do
        sim.switchThread()
    -- etc.
-- Model 2:
        if errorMsg then
    while sim.getInt32Signal("syncSignal")~=1 do
        sim.switchThread()
    -- thread2, do task1
        sim.switchThread()
    -- etc.
If some part of the code runs non-threaded, you can still interact with it easily, for instance:
        if errorMsg then
    if canMove then
        local p=sim.getObjectPosition(objectHandle,-1)
        p[1]=p[1]+0.01
        sim.setObjectPosition(objectHandle,-1,p)
        sim.switchThread()
    canMove=true
    sim.wait(5)
    canMove=false
        sim.switchThread()
    -- etc.
In case of the walking human, the best and easiest would probably to rewrite its code to run from a thread.
Leizah
Re: Tasks sequence
Post by Leizah »
Thank you for your quick reply.
I tried something similiar using the code from the youBotAndHanoiTower model as a reference, but I was not able to set the path for the walking human, I'll make an other try.
coppelia wrote: 13 Sep 2021, 07:38 In case of the walking human, the best and easiest would probably to rewrite its code to run from a thread.
Ok, there's any tutorial/existing scene that I could use as reference?
Re: Tasks sequence
If you take Model Bill on path from release V4.2.0, then you can replace its child script with following, then it will run threaded and it will be much easier to introduce modifications:
function setColor(colorName,color)
    local objectTable=sim.getObjectsInTree(BillHandle,sim.object_shape_type)
    for i=1,#objectTable,1 do
        sim.setShapeColor(objectTable[i],colorName,0,color)
function moveBody(dist)
    if dist then
        local t1=math.mod(dist/1,1)
        local t2=math.mod(t1+0.5,1)
        sim.setJointPosition(legJointHandles[1],sim.getPathInterpolatedConfig(legWaypoints,timings,t1)[1])
        sim.setJointPosition(kneeJointHandles[1],sim.getPathInterpolatedConfig(kneeWaypoints,timings,t1)[1])
        sim.setJointPosition(ankleJointHandles[1],sim.getPathInterpolatedConfig(ankleWaypoints,timings,t1)[1])
        sim.setJointPosition(shoulderJointHandles[1],sim.getPathInterpolatedConfig(shoulderWaypoints,timings,t1)[1])
        sim.setJointPosition(elbowJointHandles[1],sim.getPathInterpolatedConfig(elbowWaypoints,timings,t1)[1])
        sim.setJointPosition(legJointHandles[2],sim.getPathInterpolatedConfig(legWaypoints,timings,t2)[1])
        sim.setJointPosition(kneeJointHandles[2],sim.getPathInterpolatedConfig(kneeWaypoints,timings,t2)[1])
        sim.setJointPosition(ankleJointHandles[2],sim.getPathInterpolatedConfig(ankleWaypoints,timings,t2)[1])
        sim.setJointPosition(shoulderJointHandles[2],sim.getPathInterpolatedConfig(shoulderWaypoints,timings,t2)[1])
        sim.setJointPosition(elbowJointHandles[2],sim.getPathInterpolatedConfig(elbowWaypoints,timings,t2)[1])
        for i=1,2,1 do
            sim.setJointPosition(legJointHandles[i],0)
            sim.setJointPosition(kneeJointHandles[i],0)
            sim.setJointPosition(ankleJointHandles[i],0)
            sim.setJointPosition(shoulderJointHandles[i],0)
            sim.setJointPosition(elbowJointHandles[i],0)
    sim.setThreadAutomaticSwitch(false)
    for journey=1,maxJourneys,1 do
        if journey==1 then
            sim.wait(startPosInitialPause)
            sim.wait(startPosPause)
        local dist=0
        local st=sim.getSimulationTime()
        while dist<pathL do
            local dt=sim.getSimulationTime()-st
            dist=velocity*dt
            local p=sim.getPathInterpolatedConfig(pathPositions,pathLengths,dist)
            p=sim.multiplyVector(pathM,p)
            local pp=sim.getObjectPosition(BillHandle,-1)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            sim.setObjectOrientation(BillHandle,-1,{0,0,math.atan2(dy,dx)})
            sim.setObjectPosition(BillHandle,-1,p)
            moveBody(dist)
            sim.switchThread()
        moveBody()
        sim.wait(goalPosPause)
        local dist=pathL
        while dist>0 do
            dist=pathL-velocity*dt
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        moveBody()
    BillHandle=sim.getObjectHandle('Bill_base')
    legJointHandles={sim.getObjectHandle('Bill_leftLegJoint'),sim.getObjectHandle('Bill_rightLegJoint')}
    kneeJointHandles={sim.getObjectHandle('Bill_leftKneeJoint'),sim.getObjectHandle('Bill_rightKneeJoint')}
    ankleJointHandles={sim.getObjectHandle('Bill_leftAnkleJoint'),sim.getObjectHandle('Bill_rightAnkleJoint')}
    shoulderJointHandles={sim.getObjectHandle('Bill_leftShoulderJoint'),sim.getObjectHandle('Bill_rightShoulderJoint')}
    elbowJointHandles={sim.getObjectHandle('Bill_leftElbowJoint'),sim.getObjectHandle('Bill_rightElbowJoint')}
    neckJoint=sim.getObjectHandle('Bill_neck')
    pathHandle=sim.getObjectHandle('Bill_path')
    local pathData=sim.unpackDoubleTable(sim.readCustomDataBlock(pathHandle,'PATH'))
    local m=Matrix(#pathData//7,7,pathData)
    pathPositions=m:slice(1,1,m:rows(),3):data()
    pathLengths,pathL=sim.getPathLengths(pathPositions,3)
    pathM=sim.getObjectMatrix(pathHandle,-1)
    velocity=1
    setRandomColors=true
    startPosInitialPause=0
    startPosPause=3
    goalPosPause=3
    maxJourneys=9999
    -- Now we set random colors:
    HairColors={4,{0.30,0.22,0.14},{0.75,0.75,0.75},{0.075,0.075,0.075},{0.75,0.68,0.23}}
    skinColors={2,{0.91,0.84,0.75},{0.52,0.45,0.35}}
    shirtColors={5,{0.37,0.46,0.74},{0.54,0.27,0.27},{0.31,0.51,0.33},{0.46,0.46,0.46},{0.18,0.18,0.18}}
    trouserColors={2,{0.4,0.34,0.2},{0.12,0.12,0.12}}
    shoeColors={2,{0.12,0.12,0.12},{0.25,0.12,0.045}}
    if setRandomColors then
        math.randomseed(sim.getFloatParam(sim.floatparam_rand)*10000) -- each lua instance should start with a different and 'good' seed
        setColor('HAIR',HairColors[1+math.random(HairColors[1])])
        setColor('SKIN',skinColors[1+math.random(skinColors[1])])
        setColor('SHIRT',shirtColors[1+math.random(shirtColors[1])])
        setColor('TROUSERS',trouserColors[1+math.random(trouserColors[1])])
        setColor('SHOE',shoeColors[1+math.random(shoeColors[1])])
    -- Data for body movement:
    timings={0,1/21,2/21,3/21,4/21,5/21,6/21,7/21,8/21,9/21,10/21,11/21,12/21,13/21,14/21,15/21,16/21,17/21,18/21,19/21,20/21,21/21}
    legWaypoints={0.237,0.228,0.175,-0.014,-0.133,-0.248,-0.323,-0.450,-0.450,-0.442,-0.407,-0.410,-0.377,-0.303,-0.178,-0.111,-0.010,0.046,0.104,0.145,0.188,0.237}
    kneeWaypoints={0.282,0.403,0.577,0.929,1.026,1.047,0.939,0.664,0.440,0.243,0.230,0.320,0.366,0.332,0.269,0.222,0.133,0.089,0.065,0.073,0.092,0.282}
    ankleWaypoints={-0.133,0.041,0.244,0.382,0.304,0.232,0.266,0.061,-0.090,-0.145,-0.043,0.041,0.001,0.011,-0.099,-0.127,-0.121,-0.120,-0.107,-0.100,-0.090,-0.133}
    shoulderWaypoints={0.028,0.043,0.064,0.078,0.091,0.102,0.170,0.245,0.317,0.337,0.402,0.375,0.331,0.262,0.188,0.102,0.094,0.086,0.080,0.051,0.058,0.028}
    elbowWaypoints={-1.148,-1.080,-1.047,-0.654,-0.517,-0.366,-0.242,-0.117,-0.078,-0.058,-0.031,-0.001,-0.009,0.008,-0.108,-0.131,-0.256,-0.547,-0.709,-0.813,-1.014,-1.148}
        if errorMsg then
function sysCall_cleanup()
    -- Restore to initial colors:
    setColor('HAIR',HairColors[2])
    setColor('SKIN',skinColors[2])
    setColor('SHIRT',shirtColors[2])
    setColor('TROUSERS',trouserColors[2])
    setColor('SHOE',shoeColors[2])
Leizah
Re: Tasks sequence
Post by Leizah »
Thank you so much!
I've an issue with that code, now Bill stops when he has to and waits for the signal from the robot, but when the robot ends its task Bill just "pops" into the final position.
He doesn't move from when he stopped, he "desappears" from that position and reappear in an other position of the path.
How could I fix this?
Again, thank you for you support
Re: Tasks sequence
If you have a wait in there somewhere, you should adjust the st variable, i.e. distance on the path is calculated with:
dist=velocity*dt
where st is the start time. If you wait somewhere, then you'll have to correct the start time with the waiting time, e.g.:
    while dist<pathL do
        st=st+waitFunction()
        dist=velocity*dt
        local dx=p[1]-pp[1]
        local dy=p[2]-pp[2]
        moveBody(dist)
        sim.switchThread()
function waitFunction
    sim.waitForSignal('mySignal')
    return sim.getSimulationTime()-st
Leizah
Re: Tasks sequence
Post by Leizah »
Thank you, it works just as I wanted!
Even if the original question is now solved, I would like to know if it's possible, using the threated script, to evaluate the position into the path of a point with a command.
In other words, the value of 60% that I've set has been found after many tries, and if I move one of the contol point Bill will not stop where I need.
I would like to get something like "When you're on the point of the path closest to the object A, stop and turn to that object".
I tried with the non-threated script using the sim.getClosestPosOnPath function, but I was not able to find out how to achieve this result (The function returned always a value of 0).
However, thank you again for you help with the task sequence issue.
Re: Tasks sequence
In next release (i.e. V4.3.0), the Bill on path model will be able to do that. You can already get it here.
Leizah
Re: Tasks sequence
Post by Leizah »
I'm just struggling on how to merge this model with the task sequence code, because this model allows me to stop and modify orientation, but I need to set conditions in order to trigger the signals.
EDIT
I'm using the following code:
 while dist<pathL and dist<pathL*Stop_Condition do
            dist=velocity*dt
            st=st+handlePossiblePause(1,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        while dist<pathL and dist>pathL*Stop_Condition do
            dist=velocity*dt
            st=st+waitFunction()+handlePossiblePause(1,dist)
            local dx=p[1]-pp[1]
            local dy=p[2]-pp[2]
            moveBody(dist)
            sim.switchThread()
        moveBody()
        Stop_Point=sim.getObjectHandle('Stop_Point_4')
        Stop_Point_Coords=sim.getObjectPosition(Stop_Point,-1)
        Stop_Point_Path=sim.getClosestPosOnPath(pathPositions,pathLegths,Stop_Point_Coords)
        Stop_Condition=Stop_Point_Path/PathL
It works, but I cannot make Bill stop when he reaches the pause point.
He walks, then stops when he reaches Stop_Condition I set, then he waits for the robot signal and the, when he restarts, pauses again because he reaches the pausePoint. I would like to make the two pauses to "merge", in order to get a more precise movement.
There's any way to do that?
I also have another problem, I set 4 pausePoints, with the second and the forth in the same position (but obtained using different elements), I set all dir values to 3 (when I set it to 2 the model doesn't stop), but Bill doesn't stop when he reaches the last point.
He basically stops only on the first 3 pausePoints, missing the last one.
Again, thank you so much for your support.
Leizah
Re: Tasks sequence
Post by Leizah »
I'm sorry to re-up this topic, but I'm still struggling with the issue described into the previous answer and I would like to know If I I can set to "avoid" the 4th stop point during the first part of the travel of Bill.
