Misalignment of text on script
iruka
Post by iruka »
I started up coppeliasim for the first time in a few days, and found a strange blank space on the script. When I click on it, the position is shifted. I wonder why this is?
iruka
Re: Misalignment of text on script
Post by iruka »
that is very strange. What platform are you using? Also, do all scripts look like that, or only those that you have edited?
Finally, you can try to change the font via file system/usrset.txt, and modifying the scriptEditorFont variable, e.g.:
scriptEditorFont = Times
iruka
Post by iruka »
Thanks for the reply.
I use Mac.
I use Newton as the engine.
All scripts look like that.
I changed the font to "times", and now I get the following
https://drive.google.com/file/d/1pFaELe ... sp=sharing
Maybe try with other fonts. The problem is not directly linked with CoppeliaSim. Possibly linked with QScintilla (which CoppeliaSim uses), or your system.
