MAC script typing format weird
I find the format like the space and the layout of in-scene script on mac look very weird, is this some compatibility issue?
Thank you!
Thank you!
Re: MAC script typing format weird
can you share a screenshot? What exactly is weird?
https://drive.google.com/file/d/1ZDdJoH ... sp=sharingcoppelia wrote: ↑21 Feb 2022, 15:37 Please share it via dropBox or similar. Or you can also send it to us directly.
https://drive.google.com/file/d/1Qebt-I ... sp=sharing
I put them into a google drive file, thank you!
In the code section, you can see the format is very messy, and when I try to type more code or delete or just move my cursor, it's all very weird.
Can you tell me what macOS version, and what CoppeliaSim version you are using?
Can you try to select a different font by modifying value scriptEditorFont in file coppeliaSim/Contents/macOS/system/usrset.txt?
e.g. Courier, Serif, Georgia, etc.
Hello, yes.
I'm using macOS Monterey (12.1) on MacBook Air 2020 M1, I tried both 4.2 and 4.3 coppeliasim but they are the same on this issue.
Hello, I tried Courier and Serif, Serif seems to work well now. Thank you very much!
I'd recommend to use a monospaced font, otherwise it will be more difficult to read/write code. Check your system what is available, e.g. Consolas
