simIK.generatePath fails
siilats
Post by siilats »
I get
raise Exception(resp.get('error'))
Exception: ...oppeliaSim.app/Contents/MacOS/../Resources/lua/simIK.lua:188: attempt to index a nil value (field 'ikEnvs')
I see in the wizard it generates code with _ but even if I change it
 ikElement,ikHandleMap,ikToSimMap=simIK.addElementFromScene(ikEnv,ikGroup,simBase,simTip,simTarget,constraint)
it didnt help. changing manually in simIK.lua
function simIK.debugGroupIfNeeded(ikEnv,ikGroup,debugFlags)
    if not _S.ikEnvs then
        _S.ikEnvs={}
fixes it
Re: simIK.generatePath fails
yes, you are right. This happens when you create an IK task not via simIK.addElementfromScene. Did you run a specific CoppeliaSim example or scene that triggered that?
