How to use the Suction pad
dyu
Post by dyu »
I'm trying to use the built in suction cup to pick up an object. Does the object I am trying to pick up have to be both respondable and dynamic for this to work? Or will it work if it is neither, or only respondable?
The object I have right now is respondable and dynamic, but I'm not being able to pick it up. Here is the suction pad child script:
function sysCall_init()
    s=sim.getObjectHandle('suctionPadSensor')
    l=sim.getObjectHandle('suctionPadLoopClosureDummy1')
    l2=sim.getObjectHandle('suctionPadLoopClosureDummy2')
    b=sim.getObjectHandle('suctionPad0')
    suctionPadLink=sim.getObjectHandle('suctionPadLink')
    infiniteStrength=sim.getScriptSimulationParameter(sim.handle_self,'infiniteStrength')
    maxPullForce=sim.getScriptSimulationParameter(sim.handle_self,'maxPullForce')
    maxShearForce=sim.getScriptSimulationParameter(sim.handle_self,'maxShearForce')
    maxPeelTorque=sim.getScriptSimulationParameter(sim.handle_self,'maxPeelTorque')
    sim.setLinkDummy(l,-1)
    sim.setObjectParent(l,b,true)
    m=sim.getObjectMatrix(l2,-1)
    sim.setObjectMatrix(l,-1,m)
function sysCall_cleanup()
function sysCall_sensing()
    parent=sim.getObjectParent(l)
    if (sim.getScriptSimulationParameter(sim.handle_self,'active')==false) then
        if (parent~=b) then
        if (parent==b) then
            -- Here we want to detect a respondable shape, and then connect to it with a force sensor (via a loop closure dummy dummy link)
            -- However most respondable shapes are set to "non-detectable", so "sim.readProximitySensor" or similar will not work.
            -- But "sim.checkProximitySensor" or similar will work (they don't check the "detectable" flags), but we have to go through all shape objects!
            index=0
            while true do
                shape=sim.getObjects(index,sim.object_shape_type)
                if (shape==-1) then
                    break
                if (shape~=b) and (sim.getObjectInt32Parameter(shape,sim.shapeintparam_respondable)~=0) and (sim.checkProximitySensor(s,shape)==1) then
                    -- Ok, we found a respondable shape that was detected
                    -- We connect to that shape:
                    -- Make sure the two dummies are initially coincident:
                    -- Do the connection:
                    sim.setObjectParent(l,shape,true)
                    sim.setLinkDummy(l,l2)
                    break
                index=index+1
            -- Here we have an object attached
            if (infiniteStrength==false) then
                -- We might have to conditionally beak it apart!
                result,force,torque=sim.readForceSensor(suctionPadLink) -- Here we read the median value out of 5 values (check the force sensor prop. dialog)
                if (result>0) then
                    breakIt=false
                    if (force[3]>maxPullForce) then breakIt=true end
                    sf=math.sqrt(force[1]*force[1]+force[2]*force[2])
                    if (sf>maxShearForce) then breakIt=true end
                    if (torque[1]>maxPeelTorque) then breakIt=true end
                    if (torque[2]>maxPeelTorque) then breakIt=true end
                    if (breakIt) then
                        -- We break the link:
What is the correct way to activate this suction pad? Could you please provide an example lua script?
Thank you for your time
Re: How to use the Suction pad
so it seems you are using the suction pad model that comes with CoppeliaSim. You can see that there is a proximity sensor (very small, and hidden in a hidden layer) that checks if a shape is detected. So the first question: does your shape get detected?
The script you are referring to specifically checks for non-static, respondable shapes. But technically, you could also check only for non-static shapes.
dyu
Post by dyu »
It turns out my shape doesn't even get detected. It's a respondable, dynamic shape.
Here is my scene:
https://drive.google.com/file/d/1GIrRgp ... sp=sharing
What could be going wrong?
Note for the scene: I just need one suction to work, the others are dummies. I've been testing with suctionPad0
In your scene nothing is moving. What shape is supposed to get detected? And how does the movement look like?
Of course if the proximity sensor of your suction pad doesn't get close enough to touch the object, it won't be detected. Make visually sure that the ray-type proximity sensor intersects with the shape you want to detect. Output some text here and there in the child script of the suction pad, to make sure that the code executes as expected. You can also try to adjust the volume properties of the proximity sensor, e.g. to make it longer.
dyu
Post by dyu »
Thanks! It turned out that the proximity sensor was too far inside the suction pad, and therefore the object wasn't getting detected. I adjusted it's position and now it works fine.
mecabot
Post by mecabot »
How can I detach the object from the suctionPad?
Just change the parent of the linked dummy, the one attached to your object:
i.e. from:
pickedPart --> linkedDummyB
to:
pickedPart
You'd do that with sim.setObjectParent. But normally the suction pad code does that for you: in that code, you have an enabled variable that you should turn to false.
