Pb (bug?) with custom ROS2 service
juhel
Post by juhel »
My goal is to create a ROS2 service to get the image from a vision sensor. To do this, I follow these steps :
1/ Publish a ROS2 message Image from an PNG file
 import rclpy
from rclpy.node import Node
import cv2
from cv_bridge import CvBridge
from sensor_msgs.msg import Image
class Publisher(Node):
    def __init__(self):
        super().__init__('publisher')
        self.publisher = self.create_publisher(Image, 'image', 1)
    def publish(self):
        cv_image = cv2.imread('cylinder.png')
        # Convert OpenCV image to ROS Image message
        bridge = CvBridge()
        ros_image = bridge.cv2_to_imgmsg(cv_image, encoding='bgr8')
        self.publisher.publish(ros_image)
def sysCall_init():
    sim = require('sim')
    rclpy.init()
    self.publisher_node = Publisher()
def sysCall_sensing():
    self.publisher_node.publish()
    rclpy.spin_once(self.publisher_node, timeout_sec=0)
def sysCall_cleanup():
    self.publisher_node.destroy_node()
    rclpy.shutdown()
And I can see this image with :
ros2 run image_view image_view --ros-args --remap image:=/image
This code validates that I can read a PNG image and send it as a sensor_msgs.msg.Image message.
Scene : https://drive.google.com/file/d/1bRa8gy ... sp=sharing
2/ Create a ROS2 service with a custom message based on Image
I defined the MyImage service message in a tutorial_interfaces ROS2 package :
MyImage.srv file
sensor_msgs/Image image
Now, I test that I can use this new message to define a ROS2 service with this image_server.py program :
import rclpy
from tutorial_interfaces.srv import MyImage
from std_msgs.msg import Header
from builtin_interfaces.msg import Time
import cv2
import os
class ImageServer(Node):
    def __init__(self):
        super().__init__('image_server')
        self.srv = self.create_service(MyImage, 'vision_sensor', self.service_callback)
        self.bridge = CvBridge()
        # Specify the path to your image file
        self.image_path = 'cylinder.jpg'  # Update this path
    def service_callback(self, request, response):
        self.get_logger().info('Incoming request for image')
        # Read the image using OpenCV
        if not os.path.exists(self.image_path):
            self.get_logger().error(f'Image file not found: {self.image_path}')
            return response
        cv_image = cv2.imread(self.image_path)
        if cv_image is None:
            self.get_logger().error('Failed to read image')
            return response
        ros_image = self.bridge.cv2_to_imgmsg(cv_image, encoding='bgr8')
        # Populate the response
        response.image = ros_image
        return response
def main(args=None):
    rclpy.init(args=args)
    image_server = ImageServer()
    rclpy.spin(image_server)
    image_server.destroy_node()
    rclpy.shutdown()
if __name__ == '__main__':
    main()
and test it with this client.py file :
# image_service/image_service/image_client.py
import rclpy
import cv2
class ImageClient(Node):
    def __init__(self):
        super().__init__('image_client')
        self.cli = self.create_client(MyImage, 'vision_sensor')
        while not self.cli.wait_for_service(timeout_sec=1.0):
            self.get_logger().info('Waiting for service...')
        self.req = MyImage.Request()
    def send_request(self):
        future = self.cli.call_async(self.req)
        rclpy.spin_until_future_complete(self, future)
        if future.result() is not None:
            self.get_logger().info('Received image response')
            ros_image = future.result().image
            cv_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8')
            cv2.imshow('Received Image', cv_image)
            cv2.waitKey(0)
            cv2.destroyAllWindows()
        else:
            self.get_logger().error('Service call failed')
    image_client = ImageClient()
    image_client.send_request()
    image_client.destroy_node()
    rclpy.shutdown()
    main()
And I can see the image so it prove that I can create a service with this new MyImage message (all is OK with ROS2).
3/ Coppelia + ROS2 MyImage service
I have this Coppelia python script :
# Ensure that this script is added as a threaded child script in CoppeliaSim
# Set the script's interpreter to Python
import numpy as np
import cv2
def sysCall_init():
    simROS2 = require('simROS2')
    self.visionSensor = sim.getObject('/visionSensor')
    global srv
    sim.addLog(sim.verbosity_msgs, 'Thread started')
    # Create the ROS2 service
    srv = simROS2.createService('/vision_sensor', 'tutorial_interfaces/srv/MyImage', srv_callback)
def sysCall_thread():
    while not sim.getSimulationStopping():
        # Keep the thread alive
        sim.wait(0.01)  # Wait for 10ms before the next iteration
def srv_callback(req):
    sim.addLog(sim.verbosity_msgs, f'Service called: {req}')
    # Create the response
    resp = simROS2.createInterface('tutorial_interfaces/srv/MyImageResponse')
    print('==================')
    bridge = CvBridge()
    bridge = CvBridge()
    resp['image'] = ros_image
    print('image generated')
    return resp
    # Shutdown the ROS2 service
    simROS2.shutdownService(srv)
    sim.addLog(sim.verbosity_msgs, 'Thread finished')
Scene : https://drive.google.com/file/d/1tSr289 ... sp=sharing
Now I test the service :
ros2 service call /vision_sensor tutorial_interfaces/srv/MyImage
Here's the result :
[/scriptCamera:info] Service called: {}
image generated
[/scriptCamera:warning] Received non-serializable data: {'image': sensor_msgs.msg.Image(header=std_msgs.msg.Header(stamp=builtin_interfaces.msg.Time(sec=0, nanosec=0), frame_id=''), height=100, width=100, encoding='bgr8', is_bigendian=0, step=300, data=[198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198, 206, 217, 198,
So, why do I have this serialization error and not in the case of Topic.
Regrads,
Philippe
