I need to import a mesh in the scene. After the import of the mesh is complete, I see that the mesh is dipped into the floor. How can i get rid of that?
Floor box size change
Re: Floor box size change
not sure I understand what you mean. Do you mean that the imported mesh is below the floor? If this is the case, simply shift it above the floor. Or scale the imported mesh if the dimensions are not correct [Menu bar > Modules > Geometry / Mesh > Isometric scaling...].
