Crash in while loop
juyeon
Re: Crash in while loop
Post by juyeon »
function sysCall_actuation()
        if errorMsg then
function sysCall_cleanup()
    -- do some clean-up here
function coroutineMain()
    -- Put some initialization code here
     model=sim.getObject('.')
    --fire=sim.getObject('/fire')
    leftJointHandle=sim.getObject("./leftJoint_")
    rightJointHandle=sim.getObject("./rightJoint_")
    goal = sim.getObject('/Cuboid1')
    cont=sim.addDrawingObject(sim.drawing_linestrip+sim.drawing_cyclic,2,0,-1,2000,{1,0,0})
    initial_model_pos=sim.getObjectPosition(model,-1)
    --recive_x = initial_model_pos[1]
    --recive_y = initial_model_pos[2]
    recive_x = 0
    recive_y = 0
    recive_ang =0
    angle=0
    arrive_sig=0
    -- Put your main loop here, e.g.:
    while true do
    --     local p=sim.getObjectPosition(objHandle,-1)
    --     p[1]=p[1]+0.001
    --     sim.setObjectPosition(objHandle,-1,p)
    --     sim.switchThread() -- resume in next simulation step
     sim.setObjectPosition(goal,-1,{recive_x,recive_y,0.050})
    rel_pos = sim.getObjectPosition(goal,model)
    rel_y = rel_pos[2]
    rel_z = rel_pos[3]
    theta = math.atan(rel_y/rel_z)
    if  recive_ang==0 then
        if rel_y>=0 and rel_z<=0 and theta<-0.02 then
            sim.setJointTargetVelocity(rightJointHandle,100*math.pi/180)        --turn left
            sim.setJointTargetVelocity(leftJointHandle,50*math.random()*math.pi/180)
        elseif rel_y>=0 and rel_z>=0 and theta>0.02 then
        elseif rel_y<=0 and rel_z<=0 and theta>0.02 then
            sim.setJointTargetVelocity(leftJointHandle,100*math.pi/180)           --turn right
            sim.setJointTargetVelocity(rightJointHandle,50*math.random()*math.pi/180)
        elseif rel_y<=0 and rel_z>=0 and theta<-0.02 then
        elseif math.abs(theta)<=0.02 then
            sim.setJointTargetVelocity(leftJointHandle,200*math.pi/180)         --go forward
            sim.setJointTargetVelocity(rightJointHandle,200*math.pi/180)
        if math.abs(rel_y)<=0.02 and math.abs(rel_z)<=0.02 then
            sim.setJointTargetVelocity(leftJointHandle,0)         --stop
            sim.setJointTargetVelocity(rightJointHandle,0)
            if math.abs(model_pos[1]-initial_model_pos[1])>0.3 and math.abs(model_pos[2]-initial_model_pos[2])>0.3 then
                arrive_sig=1
            arrive_sig=0
    elseif recive_ang ~=0  then
        --mar={9.4195546873621e-07, -0.99749498659008, -0.070737201858524, 1.0, 1.3282911062062e-05, 0.070737201864796, -0.99749498650164, 1.0, 0.99999999991134, -1.0319523013891e-13, 1.3316268485664e-05, 0.05}
        model_matrix = sim.getObjectMatrix(model,-1)
        --as,res = sim.getRotationAxis(model_matrix,mar)
        --print(as)
        --print(model_matrix)
        --print(res)
        --x = {model_matrix[1],model_matrix[5],model_matrix[9]}
        z = {0,0,1}
        pos = {model_matrix[4],model_matrix[8],0}
        --pos={0,0,0}
        goal_matrix = sim.rotateAroundAxis(model_matrix,z,pos,recive_ang)
        print('goal matrix:',goal_matrix)
        while recive_ang>0 do
        --for t=1,1000 do
            print('model matrix:',model_matrix)
            res,rota = sim.getRotationAxis(model_matrix,goal_matrix)
            print('rota',rota)
            if rota <= 0.1 then
                print('t')
                recive_ang=0
                break
If I write it like this, it can rotate to the angle I need and perform other actions normally, but it can't stop, it will circle in place.
If the same code is written in the above sysCall_actuation(), the statement of rotating to the angle I need cannot be executed, but it can stop normally without turning in circles.
It would be simpler if you explain what you are trying to achieve.
If you are trying to get the robot's yaw, you can simply take the robot's front-facing axis (in case of DR12 that would be -z) project it onto the XY plane and use math.atan2(y,x) to get the angle, e.g.:
function getYaw()
    local m=sim.getObjectMatrix(model,sim.handle_world)
    local dir={-m[3],-m[7],-m[11]}
    return math.atan2(dir[2],dir[1])
Then, if you are trying to implement a position controller, you have to understand the topology of SO(2). You can't simply take subtraction between current and target. The orientation error between 359º and 1º is not -358º! It is 2º.
You can do something like that:
function getYawError(targetYaw)
    local e=getYaw()-targetYaw
    if math.abs(e-2*math.pi)<math.abs(e) then
        return e-2*math.pi
    elseif math.abs(e+2*math.pi)<math.abs(e) then
        return e+2*math.pi
        return e
Above code is able to track robot's yaw for any target angle (e.g. by adding yaw error to left wheel velocity, and subtracting it to right wheel velocity).
juyeon
Post by juyeon »
fferri wrote: 22 May 2023, 09:25 It would be simpler if you explain what you are trying to achieve.
function getYaw()
        return e-2*math.pi
        return e+2*math.pi
        return e
Thanks a lot for your reply, I have a better understanding of rotation matrices.
I'm still relatively new to robotics, so set a target point as target tracking to control the yaw angle, and the target has been reached.
Thanks a lot for your patient reply.
