ROS Tutorial HELP !
Laurie44
Re: ROS Tutorial HELP !
Post by Laurie44 »
pr0t0z wrote:Ok, problem was in:
Nodes connect fine now.
Which file was that?
Thanks!
pr0t0z
Post by pr0t0z »
It was in a file I adapted.
Here is the malfunctioning version:
http://pastebin.com/snVi0CSN
sloppy
Post by sloppy »
I've installed V-REP V3.2.0 running on Ubuntu 14.04 64bit, which is meant to work for ROS Indigo, but I still get errors when calling ROS services
rosservice call /vrep/simRosStartSimulation
ERROR: Unable to load type [vrep_common/simRosStartSimulation].
Have you typed 'make' in [vrep_common]
The rest of the tutorial seems to be working; plugin loads, roscd finds what it's supposed to, can see an image from image_view in "rosTopicPublisherAndSubscriber.ttt" and the red bubble rob in "controlTypeExamples.ttt" moves, etc.
You need to source your environment:
source ~/catkin_ws/devel/setup.bash
(make sure you have the V-REP ROS package in ~/catkin_ws/src/)
sloppy
Post by sloppy »
Thanks! That resolved the problem
studenTU01
Post by studenTU01 »
Hello I am using Ubuntu 16.04 and ROS Kinetic in the current V-Rep Version 3.3.2 64bit.
The ROS tutorial - Hydro works for me until the tutorial reaches the rosservice call part.
The Plugins "Ros", "RosInterface" and "RosSkeleton" load succeeded with a roscore running.
I am having the same Problem as sloppy with the rosservice call:
rosservice call vrep/simRosStartSimulation
Have you typed 'make' in [vrep_common]?
I sourced my catkin_ws as explained.
I am not quite sure which "V-REP ROS package" coppelia meant, but I have the self-compiled build version of "vrep_common", "vrep_plugin" and "vrep_ros_interface" (this one I expect to be the "VREP ROS package") in my catkin_ws/src folder.
I really hope that anyone can help me.
Best Regards
this related to the old RosPlugin, that you shoudn't use anymore, since it is not that flexible, intuitive and extendable as the new RosInterface. But what you mention is not in the tutorial anymore (since V3.3.1 I believe)
studenTU01
thanks for the reply, is there any "getting started" tutorial for the new RosInterface?
I would just like to have some sort of introduction in how to use the RosInterface.
Best Regards
There are 2 examples that use the new ROS interface:
  • rosInterfaceTopicPublisherAndSubscriber.ttt
  • controlTypeExamples.ttt (the red robot, in front is using the RosInterface)
