I'm not sure I understand... it seems to me that remApiSetup.m tells where to find remApi.oct, and then loads the various commands that are available in remApi.oct- but the functions must be in remApi.oct to begin with.
I couldn't compile the new remApi.oct in the first place, because there was a wrapper function in remApi.cc (DEFUN_DLD simxCallScriptFunction) that wasn't then defined in extApi.c, as all the other wrapper functions are. I would think I'd need a new extApi.c as well as adding the load function to remApiSetup.m.
I did indeed get an invite to the beta from the forum- just missed it in my email. Thanks for the extra link though!
Max
Building remoteApi bindings for Octave 4.0
Re: Building remoteApi bindings for Octave 4.0
Oops, yes, forgot about that. Of course the extApi.c file also needs to accomodate the new command (simxCallScriptFunction). This is done since the beta version.
Any update on this? The beta links are also broken.
Regards,
Nicolae
Regards,
Nicolae
if you download the last release (i.e. V3.3.2), then you will have everything you need to correctly compile the remote API client for Octave.
