ZMQ Python, reset scene problems.
martin
Post by martin »
Hello Coppelia,
I have been using the "Legacy Remote API" for Python for a long time and I think it is time to upgrade to the new ZMQ Remote API. For this, I am working with Coppelia 4.4 on Ubuntu20.04.
With the Legacy Remote API I had been working in Synchronous mode and wanted to do the same with the ZMQ. However, I have encountered a problem in my first tests, related to the reset of the scene by a stop, and subsequent start.
I've done a simple example to show that.
import numpy as np
from zmqRemoteApi import RemoteAPIClient
def main():
    print('Program started')
    client = RemoteAPIClient()
    sim = client.getObject('sim')
    time_steps_each_evaluation = 5
    time_steps_each_angular_increment = 40
    angular_increment = 20.0 * np.pi/180.0
    while (True):
        alfa = 45.0 * np.pi/180.0
        beta = 0.0
        gama = 0.0
        client.setStepping(True)
        j1 = sim.getObject("/j1")
        j2 = sim.getObject("/j2")
        j3 = sim.getObject("/j3")
        sim.startSimulation()
        for timeStep in range(0, time_steps_each_evaluation):
            alfa = alfa + angular_increment
            beta = beta + angular_increment
            gama = gama + angular_increment
            sim.setJointTargetPosition(j1, alfa)
            sim.setJointTargetPosition(j2, beta)
            sim.setJointTargetPosition(j3, gama)
            # ----  Getting Stuck here ----
            for m in range(0, time_steps_each_angular_increment):
                client.step()
        sim.stopSimulation()
After the "sim.stopSimulation()" the simulation stops and I started it again with "client.setStepping(True)" and "sim.startSimulation()". However, I think the program usually gets stuck in the "client.step()" section of the "for" loop
I also add a link to the scene https://www.dropbox.com/s/gpmt86uqfll4s ... o.ttt?dl=0
Any help would be appreciated.
Regards!
Re: ZMQ Python, reset scene problems.
make sure that the simulation has really stopped, before starting again, e.g.:
while sim.getSimulationState()!=sim.simulation_stopped:
    pass
The stepped mode is normally reset at the end of a simulation, and you will have to reactivate it again.
If a strange behaviour persists, try to pull the zmqRemoteApi repository, there was a small change related to stepping mode.
martin
Post by martin »
Many thanks, it has solved the problem. I thought that with the ZMQ API it was not necessary to wait for the "complete stop", as it was with the legacy API.
Regards!
