Gravity compensation problem of force sensor in CoppeliaSim
Robot_XiaoXi
Post by Robot_XiaoXi »
I built the model system of robot arm, force sensor and gripper in CoppeliaSim. How do I calibrate and gravimetrically compensate the force sensor in the simulation so that the force measured by the force sensor with the gripper is equal to the external torque applied to it? Thanks.
Re: Gravity compensation problem of force sensor in CoppeliaSim
So you have a force-sensor between your arm and your gripper?
It seems you want to subtract the force caused by gripper's weight from the force-sensor's reading, is it correct?
Robot_XiaoXi
Hello ferri,
Thank you for your reply.
As you said, I have a force sensor between my arm and the hand gripper. I want to subtract the force from the gripper weight from the force sensor reading. I tried to do gravity compensation, but the sensor does not show zero after compensation. I wonder if you have a corresponding solution?
Looking forward to your reply.
Best regards,
Robot_XiaoXi
Robot_XiaoXi
fferri wrote: 21 Mar 2023, 13:39 So you have a force-sensor between your arm and your gripper?
Hello ferri,
As you said, I have a force sensor between my arm and the hand gripper. I want to subtract the force caused by gripper's weight from the force-sensor's reading. I tried to do gravity compensation, but the sensor does not show zero after compensation. I wonder if you have a corresponding solution?
Best regards,
Robot_XiaoXi
To subtract the torque/force of the gripper you have two possibilities:
  • manually compute gripper's center of mass, total mass \(m\), then express gripper's center of mass \(\vec{r}\) and gravity vector \(\vec{g}\) in force sensor's reference frame, and compute resulting force/torque (remember that torque \(\vec\tau=\vec{r} \times \left(m \vec{g}\right)\))
  • add an anti-gravity force to the gripper (sim.addForce)
The second approach is definitely simpler ;-) however it would change dynamics of your task.
For the record, to implement first proposed approach, you would first compute a list of dynamic shapes that you want to exclude from force sensor's reading, for which you'll be computing force and torque manually:
    allNonStaticShapes={}
    -- add items to 'allNonStaticShapes'
then compute mass and center of mass of those shapes (in absolute coords):
    com,mass=Vector{0,0,0},0
    for i,shape in ipairs(allNonStaticShapes) do
        local mass1=sim.getShapeMass(shape)
        local inertia,comFrame=sim.getShapeInertia(shape)
        local shapeFrame=sim.getObjectMatrix(shape,sim.handle_world)
        local m=sim.multiplyMatrices(shapeFrame,comFrame)
        com=com+mass1*Vector{m[4],m[8],m[12]}
        mass=mass+mass1
    if mass~=0 then
        com=com/mass
then convert into local coords (sensor's):
    minv=sim.getObjectMatrix(sensorHandle,sim.handle_world);sim.invertMatrix(minv)
    minv=Matrix4x4(minv)
    com=minv:mult(com)
    minv[1][4]=0
    minv[2][4]=0
    minv[3][4]=0
    g=minv:mult(Vector{0,0,-9.81})
and finally compute force and torque caused by those shapes:
    force=g*mass
    torque=com:cross(force)
force and torque are also in sensor's reference frame.
Please note that everything's said is only valid for a static configuration. If the robot moves, there are other accelerations that are not taken into account.
Robot_XiaoXi
fferri wrote: 22 Mar 2023, 15:14 To subtract the torque/force of the gripper you have two possibilities:
hello fferri,
Thank you for your answer.
You have used two ways to compensate for gravity and I understand how to calculate it, thank you very much for your detailed reply.
Best regards,
Robot_XiaoXi
Robot_XiaoXi
fferri wrote: 22 Mar 2023, 16:16 For the record, to implement first proposed approach, you would first compute a list of dynamic shapes that you want to exclude from force sensor's reading, for which you'll be computing force and torque manually:
        mass=mass+mass1
    if mass~=0 then
        com=com/mass
    com=minv:mult(com)
    minv[1][4]=0
    minv[2][4]=0
    minv[3][4]=0
    force=g*mass
hello fferri,
For the static power compensation of the above system, I have successfully done it according to the method you provided. If the robot moves, how should I compensate dynamically?
Best regards,
Robot_XiaoXi
In dynamic conditions you would have to consider:
Robot_XiaoXi
fferri wrote: 27 Mar 2023, 09:43 In dynamic conditions you would have to consider:
Hello fferri, thanks for your answer!Your answer is very helpful to me, thanks.
