Confusion about sim.moveToPose
Beiguagua
Post by Beiguagua »
In c++, the argument of sim.moveToPose is as follow:
std::tuple<std::vector<double>, double> sim::moveToPose(int64_t flags, std::vector<double> currentPose, std::vector<double> maxVel, std::vector<double> maxAccel, std::vector<double> maxJerk, std::vector<double> targetPose, std::string callback, std::optional<json> auxData, std::optional<std::vector<double>> metric, std::optional<double> timeStep)
I don't know what callback is. The type of callback is string. Shouldn't it be a function? Is it defined in a child script? But I found that in the example sendIkMovementSequence-simMoveToPose, this function is defined in python, so should it be defined in c++, and if so, how should this function be defined?
Re: Confusion about sim.moveToPose
the sim.moveToPose API command has to be used from within a Lua script, in CoppeliaSim. From an external application you can however trigger such calls, e.g. via sim.callScriptFunction, a little bit in a similar way as is described here:
using blocking functions from an external application.
