Hello everbody,
I using CoppeliaSim Edu, Version 4.5.1 (rev 4) 64bit (serialization version 24) in Ubuntu 22.04.2 LTS.
My PC has the follow configurations:
- Intel(R) Core(TM) i5-4440 CPU @ 3.10GHz
- 8GB RAM
- 500 GB SSD
- video card: NVIDIA GeForce GTX 650 Ti (nvidia-driver-470 on Ubuntu)
My problem is that the simulation speed is very slow when a small number of objects are placed in the scene.
For example, when I insert the pioneer p3dx in the default scenario, the simulation runs at a good speed.
However, when 3 more standard Coppeliasim quadcopters are inserted, the simulation performance drops a lot.
I don't think this could be happening, as my PC's configuration can support some degree of simulation complexity, without performance being so low.
Any advice?
CoppeliaSim Edu, Version 4.5.1 is slow in Ubuntu 22.04.2 LTS
Re: CoppeliaSim Edu, Version 4.5.1 is slow in Ubuntu 22.04.2 LTS
you need to identify the source of that slow-down. What is the bottleneck?
Most of the time it is rendering, or physics calculations.
You can also use sim.getSystemTime in the main script to quickly identify what takes a lot of compute. Just don't forget to restore the main script to its original after that.
