Chai3d Point constraint interacting with haptic object
dkchaisumdet
Post by dkchaisumdet »
When using a point constraint on the Chai3d Vrep module constrained to the End effector of my robot with the haptic tool cursor being fairly large how can i dampen the massive vibrations that there are when my cursor (close to the point contraint) and the mesh are close to each other.
https://imgur.com/u9t4255
I've tried changing the viscosity variable in the point constraint function ptKv thinking it would dampen large vibrations but that makes even more vibrations?
Is my simulation time step too slow or something (dt=0.0500)?
There is also nothing printing to the console window.
Ive tried to make the ptKp and ptKv variables change with the error between the cursor and the pt constraint too.
ptKp=kpgain*error
ptKv=kvgain/error
To make it so that the viscosity is high as the error comes close to zero and vice versa for the stiffness.
I have no other ideas about what to do.
Please help!
Thank you!
Re: Chai3d Point constraint interacting with haptic object
we are a little bit out of excercise with the CHAI3D usage...
The CHAI3D library will run its own high-frequency loop to provide a haptic function. That loop runs much more often that CoppeliaSim simulation loop. However: when you modify some properties within the CoppeliaSim loop, those modifications, only get picked up as the same speed as CoppeliaSim's loop, obviously.
Vibrations should thus be handled in the low-level, by CHAI3D directly (i.e. CHAI3D settings).
dkchaisumdet
Do you know where abouts i can modify these settings?
dkchaisumdet
dkchaisumdet wrote: 17 May 2023, 12:44 Hi,
Just asking this again.
Unfortunately no. Try to ask on the CHAI3D forum, they would be in a much better position to answer this.
