Add External Force/Torque to UR3 robot
boyuchenuob
Post by boyuchenuob »
I am attempting to simulate applying external force to the end-effector of UR3 robot. For this task, I've employed the sim.addForceAndTorque function, and applied the torque specifically to the z-axis of the robot's last link, all the while keeping the robot in the position dynamic mode.
However, I've encountered an intriguing phenomenon for which I can't figure out the cause. When I set the torque value to 10, the robot begins to revolve at a consistent angular speed. However, if the value is less than 10, the robot remains stationary, whereas, when the value is greater than 10, the robot's speed of revolution increases progressively. I am wondering about the physics settings underlying this behaviour. And does this phenomenon mirror the real-world scenarios?
I have attached the script I used in the child script. Looking for an explanation. Thank you very much.
Kind regards,
Boyu
    connectionHandle = sim.getObject('/UR3/connection')
    link6Handle = sim.getObject('/UR3/link6')
function sysCall_cleanup()
function sysCall_actuation()
    local force = {0, 0, 0}
    local torque = {0, 0, 10}
    sim.addForceAndTorque(link6Handle, force, torque)
    -- Get the force sensor measurements
    local result, forceVector, torqueVector = sim.readForceSensor(connectionHandle)
    if result > 0 then
        print("Force: ", table.unpack(forceVector))
        print("Torque: ", table.unpack(torqueVector))
        print('No contact force')
boyuchenuob
Re: Add External Force/Torque to UR3 robot
Further to my question. I realized that the phenomenon is because I set the motor to dynamic position mode, in which the lower-level robot controller could resist a certain amount of external force/torque.
For my task, I would like to make the robot only react to the external force while compensating the effect of gravity. To achieve this, I believe that the robot joint should be set to dynamic force mode. I am also aware that it requires inverse dynamics calculation, which is very problematic. I am wondering if there is any demo or simply way to do that? Please give me a hand. Thank you.
Kind regards,
Boyu
force/torque control indeed required inverse dynamics. It is used internally, but not exposed.
Maybe have also a look at this page, which offers some resources in that direction (even if based on an old version of CoppeliaSim).
boyuchenuob
Thank you for the reply.
Could you please send the link for the webpage again? I could not see it in the chat box.
Cheers.
Kind regards,
Boyu
Sorry, forgot this link
