How can i convert speed to position with the api python
qwerty
Post by qwerty »
How can i convert speed to position. I have a file with speed data on my computer and i want to make my object move. How can i do it ?
Re: How can i convert speed to position with the api python
what does the file look like? I mean what does speed data mean? Is it a list of speed value, associated with time values? Where your object would have infinite acceleration geoing from one speed value to the next?
qwerty
Post by qwerty »
First of all, thank you for your quick response.
The file is a . CSV generate after the measurement. In this file I have acceleration and speed according to x,y and z. and I also have time. So these data are associated.
You can try with something like that:
speedData={{time=10,speed={0.1,0,0}},
{time=10.5,speed={0.2,0,0}},
{time=11,speed={0.01,0,0}},
{time=15,speed={0,0,0}},
{time=20,speed={-0.1,0,0}},
{time=40,speed={0,0,0}}
function sysCall_actuation()
        if errorMsg then
function coroutineMain()
    local dt=sim.getSimulationTimeStep()
    local i=1
    local h=sim.getObject('.')
    while i<=#speedData do
        local speed=speedData[i].speed
        print(speed)
        while sim.getSimulationTime()<speedData[i].time do
            local p=sim.getObjectPosition(h,sim.handle_world)
            p[1]=p[1]+speed[1]*dt
            p[2]=p[2]+speed[2]*dt
            p[3]=p[3]+speed[3]*dt
            sim.switchThread()
            sim.setObjectPosition(h,sim.handle_world,p)
        i=i+1
Make sure the object you want to move is not dynamically enabled, so that you can instantaneously set its position.
