Problem with Ros custom msg
Mildred34
Post by Mildred34 »
I add geometry_msgs/msg/Pose and geometry_msgs/msg/Point to interfaces.txt then I recompile the ros2 plugin.
On my ubuntu Computer when I do:
    Pose={}
    pos={}
    pos.x=objPos[1]
    pos.y=objPos[2]
    pos.z=objPos[3]
    ori={}
    ori.x=objOri[1]
    ori.y=objOri[2]
    ori.z=objOri[3]
    ori.w=objOri[4]
    Pose.orientation=ori
    Pose.position=pos
    if simROS2 then
        simROS2.publish(publisher,ori)
I received the following error:
in simROS2.publish@simExtROS2: read in arg 1 (publisherHandle): expected string
stack traceback:
    [C]: in function 'simROS2-typecheck.publish'
    [string "/IRB140[1]/robotiq2@childScript"]:80: in function 'sysCall_sensing'
But on WSL2, it's working with the same setup. It's working.
I'm working with export LIBGL_ALWAYS_SOFTWARE=1 since it looks like CoppeliaSim doesn't like my Nvidia graphic card.
It's the same on WSL2 though.
Valenorf
Re: Problem with Ros custom msg
Post by Valenorf »
On the same line, i obtain:
in simROS2.createPublisher@simExtROS2: Unsupported message type 'sensor_msgs/msg/LaserScan'. You may want to add it to meta/interfaces.txt and recompile the ROS2Interface plugin.
Of course, I added the above messages to the interface.txt file. Everything was fine with the old repo simExtROS2 (now renamed simROS2) and Coppelia 4.4.
Please post complete code.
Valenorf
Post by Valenorf »
In my case, you can find it here:
https://github.com/giulioturrisi/Differ ... simulation
The scene I'm using is dynamics.ttt
Not sure where to look at since your scene doesn't contain the code you initially posted.
And you can't get two different errors in the same script.
Try to focus only on one problem at once
Valenorf
Post by Valenorf »
Sorry, i'm not the original author of the post, and I thought that this error was related to the one that I obtain due to simROS2. I will create an additional post.
