Problem with simROS2
Valenorf
Post by Valenorf »
since the release of CoppeliaSim 4.5.1 and the rename of the module simExtROS2 to simROS2, I have the following problem with my scene at launch:
[/differential_drive/Hokuyo@childScript:error] 46: in simROS2.createPublisher@simExtROS2: Unsupported message type 'sensor_msgs/msg/LaserScan'. You may want to add it to meta/interfaces.txt and recompile the ROS2Interface plugin.
stack traceback:
[C]: in field 'createPublisher'
[string "/differential_drive/Hokuyo@childScript"]:46: in function 'sysCall_init'
[/differential_drive@childScript:error] 16: in simROS2.createSubscription@simExtROS2: Unsupported message type 'geometry_msgs/msg/Twist'. You may want to add it to meta/interfaces.txt and recompile the ROS2Interface plugin.
stack traceback:
[C]: in field 'createSubscription'
[string "/differential_drive@childScript"]:16: in function 'sysCall_init'
I added the two messages in the interfaces.txt file and recompiled. I don't think I'm doing something wrong here, since it was working normally in the past.
I'm uploading the scene:
https://github.com/giulioturrisi/Differ ... namics.ttt
Thanks,
Giulio
Re: Problem with simROS2
Before recompiling, try removing the file libsimExtROS2.so from CoppeliaSim's directory
Valenorf
Post by Valenorf »
In that case, i obtain
[/RosInterfaceHelper@customizationScript:error] ROS2 interface was not found. Cannot run.
But I have the new file libsimROS2.so created compiling the simROS2 package in the CoppeliaSim directory.
Mildred34
Post by Mildred34 »
Definitely, the same problem as me. Looking forward to hearing fom you, if you have succeeded to correct that bug !
Make sure that:
  • you installed libsimExtROS2.so into the CoppeliaSim's directory
  • you source the ROS2 environment (setup.sh / local_setup or similar) in the terminal where you would run CoppeliaSim
  • you checked plugin load message for errors
Valenorf
Post by Valenorf »
fferri wrote: 08 Jun 2023, 13:09 Make sure that:
1) when i compile the plugin, i obtain a new libsimROS2.so (not libsimExtROS2.so) in the folder. Checked deleting the old .so file everytime.
2) done
3) i don't have anymore any message regarding the load of the ros2 plugin in the terminal. Previously i had the message when it was working with Coppelia 4.4 and libsimExtROS2. Now nothing. I have only the error
inside coppelia.
I tried going back in the commit of simROS2 on github, still different problem arise. Now i will check if with coppelia 4.4 everything is ok.
If building for CoppeliaSim 4.4 (or any other specific version) you have to checkout the corresponding git branch in the plugin repository, e.g. git checkout coppeliasim-v4.4.0-rev0
Valenorf
Post by Valenorf »
Coppelia 4.4 and branch coppeliasim-v4.4.0-rev0 works fine, I confirm.
Still no clue what's happening for the new Coppelia/latest commit of simROS2. Let me know if i can do some helpful debugging
git HEAD is the development branch, usually it doesn't work with CoppeliaSim releases.
