Gas sensors in CoppeliaRobotics
kgsingh555
Post by kgsingh555 »
Hii
I would like to use a gas sensor to tap the concentration and make the
mobile robot decide its course in the arena. How it can be done? Is it
possible to simulate a plume dispersion and record its concentration
with a gas sensor?
Re: Gas sensors in CoppeliaRobotics
the best you can do is have a function the will compute a concentration wased on a 3D position, e.g.:
function getConcentration(pos)
    return(pos[1]+pos[2]+pos[3])
Then, as your robot moves in the 3D space, you can get a computed gas concentration based on the robot's position e.g. obtained with sim.getObjectPosition.
kgsingh555
coppelia wrote: 05 Jul 2023, 14:54 Hello,
Hi!! Thanks for response. For a while, I was not active on the forum. I have a case that needs plume simulation and tapping the odor concentration with gas sensor. Can the plume simulation is possible alongwith measurement of concentration at different locations with a mobile robot?
Hope my question will be addressed?
Yes.
You would compute the diffusion model yourself e.g. in sysCall_actuation() updating C[x][y][z] (the gas concentration at position x, y, z) using whatever diffusion model and environment parameters you wish.
e.g.
-- lua
    C = ... -- create new 3D grid
function sysCall_actuation()
    C_new = table.deepcopy(C)
    for i = 2, nx-1 do
        for j = 2, ny-1 do
            for k = 2, nz-1 do
                -- Update concentration
                C_new[i][j][k] = C_new[i][j][k] + ... -- C[i][j][k] is the concentration at previous step
    C = C_new
function getConcentration(x, y, z)
    local i = ...
    local j = ...
    local k = ...
    return C[i][j][k]
then from another script (e.g. from robot's script) you can call the getConcentration(x, y, z) function, using sim.callScriptFunction or sim.getScriptFunctions
kgsingh555
Thanks for reply. Is it possible to visualize the plume simulation in coppeliaSim?
Yes, you can use OcTrees, Point Clouds or Drawing Objects, and their relative APIs.
However with a dense scalar field like this, it would be difficult to look at the whole field at once. Probably you want to look at it one particular 2D slice at a time.
