Model is not displayed after importing URDF file
lin
Post by lin »
hello, I have some problems.
Model is not displayed after importing URDF file, terminal error message: sh: 1: rospack: not found
Software window prompts:
[simExtURDF:info] rospack find elite_description
[simExtURDF:error] rospack failed: Command 'rospack find elite_description' exited with status 127.
I used CoppeliaSim_Edu_V4_5_1_rev4_Ubuntu22_04 and ros2-humble.
Re: Model is not displayed after importing URDF file
Does your URDF file contain entries with $(rospack find elite_description)?
What is the output of rospack find elite_description in a terminal?
(make sure the ROS environment is sourced before running above command, and before starting CoppeliaSim in a terminal)
lin
Post by lin »
Hello, this is my URDF file
<robot
  name="frr16">
  <link
    name="base_link">
    <inertial>
      <origin
        xyz="-0.00017171 -0.00016075 0.041272"
        rpy="0 0 0" />
      <mass
        value="1.6231" />
      <inertia
        ixx="0.0039513"
        ixy="1.1032E-05"
        ixz="-1.0078E-05"
        iyy="0.0039509"
        iyz="-9.408E-06"
        izz="0.0063729" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/base_link.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <link
    name="link1">
    <inertial>
      <origin
        xyz="2.9083E-07 -0.0078554 0.17353"
        rpy="0 0 0" />
      <mass
        value="3.6493" />
      <inertia
        ixx="0.016105"
        ixy="-7.457E-08"
        ixz="-8.9981E-08"
        iyy="0.015128"
        iyz="0.00018171"
        izz="0.01184" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link1.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint1"
    type="revolute">
    <origin
      xyz="0 0 0"
      rpy="0 0 0" />
    <parent
      link="base_link" />
    <child
      link="link1" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-3.052"
      upper="3.052"
      effort="0"
      velocity="0" />
  </joint>
  <link
    name="link2">
    <inertial>
      <origin
        xyz="-0.208450295409301 -1.04141929052615E-06 0.182446410516953"
        rpy="0 0 0" />
      <mass
        value="9.46217032684362" />
      <inertia
        ixx="0.0259206341383288"
        ixy="2.52216786221599E-07"
        ixz="0.0025747972012175"
        iyy="0.379024564512205"
        iyz="1.07956448273394E-07"
        izz="0.374390438612304" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link2.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint2"
    type="revolute">
    <origin
      xyz="0 0 0.18"
      rpy="1.5708 0 0" />
    <parent
      link="link1" />
    <child
      link="link2" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-4.622"
      upper="1.482"
      effort="0"
      velocity="0" />
  </joint>
  <link
    name="link3">
    <inertial>
      <origin
        xyz="-0.233917677074643 1.15364811115182E-06 0.0482876842029215"
        rpy="0 0 0" />
      <mass
        value="2.98750118422874" />
      <inertia
        ixx="0.00387746822389482"
        ixy="2.61336049630588E-07"
        ixz="-0.00130179285621401"
        iyy="0.0545671930037123"
        iyz="-5.38789828945949E-08"
        izz="0.0540019357298666" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link3.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint3"
    type="revolute">
    <origin
      xyz="-0.52 0 0"
      rpy="0 0 0" />
    <parent
      link="link2" />
    <child
      link="link3" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-2.791"
      upper="2.791"
      effort="0"
      velocity="0" />
  </joint>
  <link
    name="link4">
    <inertial>
      <origin
        xyz="1.80050656384267E-07 -0.00259701172777185 0.154900769343231"
        rpy="0 0 0" />
      <mass
        value="2.15725431222332" />
      <inertia
        ixx="0.00330856373367053"
        ixy="1.54458983801606E-08"
        ixz="6.12273587924312E-08"
        iyy="0.00249325154735706"
        iyz="3.92564460011577E-05"
        izz="0.00314294200807018" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link4.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint4"
    type="revolute">
    <origin
      xyz="-0.4 0 0"
      rpy="0 0 0" />
    <parent
      link="link3" />
    <child
      link="link4" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-4.22"
      upper="1.482"
      effort="0"
      velocity="0" />
  </joint>
  <link
    name="link5">
    <inertial>
      <origin
        xyz="-1.79605965100471E-07 0.00259701240456633 0.109900764003892"
        rpy="0 0 0" />
      <mass
        value="2.15725428044743" />
      <inertia
        ixx="0.00330856368913726"
        ixy="1.54980608831483E-08"
        ixz="-6.11985200886753E-08"
        iyy="0.00249325151480447"
        iyz="-3.92564305005983E-05"
        izz="0.00314294193567546" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link5.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint5"
    type="revolute">
    <origin
      xyz="0 0 0.159"
      rpy="1.5708 0 0" />
    <parent
      link="link4" />
    <child
      link="link5" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-3.052"
      upper="3.052"
      effort="0"
      velocity="0" />
  </joint>
  <link
    name="link6">
    <inertial>
      <origin
        xyz="-8.51439684634858E-06 -3.21107238169943E-05 0.0824679991674052"
        rpy="0 0 0" />
      <mass
        value="0.201971657695659" />
      <inertia
        ixx="0.000112138021336963"
        ixy="5.579417291184E-10"
        ixz="5.33815248477796E-09"
        iyy="0.000112259440363443"
        iyz="9.93292688275349E-08"
        izz="0.00016839014920608" />
    </inertial>
    <visual>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
          filename="package://frr16/meshes/link6.STL" />
      </geometry>
      <material
        name="">
        <color
          rgba="1 1 1 1" />
      </material>
    </visual>
    <collision>
      <origin
        xyz="0 0 0"
        rpy="0 0 0" />
      <geometry>
        <mesh
      </geometry>
    </collision>
  </link>
  <joint
    name="joint6"
    type="revolute">
    <origin
      xyz="0 0 0.114"
      rpy="-1.5708 0 0" />
    <parent
      link="link5" />
    <child
      link="link6" />
    <axis
      xyz="0 0 1" />
    <limit
      lower="-3.052"
      upper="3.052"
      effort="0"
      velocity="0" />
  </joint>
</robot>
Terminal display:
The status bar at the bottom of the software displays:
[simExtURDF:info] creating link 'flan'...
[simExtURDF:info] rospack find frr16
[simExtURDF:error] rospack failed: Command 'rospack find frr16' exited with status 127.
[simExtURDF:info] there are 6 joints.
[simExtURDF:info] there are 7 links.
[simExtURDF:info] there are 0 sensors.
[simExtURDF:info] creating link 'base_link'...
[simExtURDF:error] neither mesh file 'frr16/meshes/base_link.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/base_link.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link1'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link1.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link1.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link2'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link2.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link2.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link3'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link3.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link3.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link4'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link4.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link4.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link5'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link5.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link5.STL' or '' with extension type 4
[simExtURDF:info] creating link 'link6'...
[simExtURDF:error] neither mesh file 'frr16/meshes/link6.STL' nor '' do exist.
[simExtURDF:error] failed to create the mesh 'frr16/meshes/link6.STL' or '' with extension type 4
Make sure your ROS environment is functional and the rospack command works.
If you can't fix your ROS environment, then don't use package:// URIs. You can manually edit the urdf file, or there's a "replace occurences of 'package://' with:" option when importing.
