The establishment of inverse kinematics solution module of vrep4.4.0 version
qsz
Post by qsz »
I would like to ask how to establish the inverse kinematics solving module in vrep4.4.0.Once it's done, call ikgroup for the sim.setExplicitHandling () operation.
Following the example:
enableIk=function(enable)
    if enable then
        sim.setObjectMatrix(ikTarget,-1,sim.getObjectMatrix(ikTip,-1))
        for i=1,#jointHandles,1 do
            sim.setJointMode(jointHandles[i],sim.jointmode_ik,1)
        sim.setExplicitHandling(ikGroup,0)
        sim.setExplicitHandling(ikGroup,1)
            sim.setJointMode(jointHandles[i],sim.jointmode_force,0)
    local simBase=sim.getObject('.')
    local simTip=sim.getObject('./tip')
    local simTarget=sim.getObject('./target')
    ikEnv=simIK.createEnvironment()
    ikGroup=simIK.createGroup(ikEnv)
    simIK.setGroupCalculation(ikEnv,ikGroup,simIK.method_pseudo_inverse,0,6)
    simIK.addElementFromScene(ikEnv,ikGroup,simBase,simTip,simTarget,simIK.constraint_pose)
The error is Ik group does not exist!!!
Re: The establishment of inverse kinematics solution module of vrep4.4.0 version
I am not sure I completely understand what you want to do. My understanding is you want to move away from the old way of handling IK, and use the new way?
Your second code section looks right:
The first part of your code is not compatible with the second part. If you want to enable/disable handling of IK, then you should add following (the actuation section was missing anyways):
function sysCall_actuation()
    if ikEnabled then
        simIK.handleGroup(ikEnv, ikGroup, {syncWorlds = true, allowError = true})
