ZMQ remote API failing after the same amount of runs of a simulation
Posted: 23 Mar 2024, 23:10
by Llamas0001
I am trying to run a lot of simulations in python and without fail it will stop working at the same point after running fine until that point.
With each simulation I am resetting the enviroment using sim.stopSimulation() and then starting it again with sim.startSimulation() after reloading the scene.
The error comes up every time before the simulation starts so I imagine its an issue occuring while its attempting to start the simulation but I am completely lost on what is actually causing the problem.
This is the error I am getting.
[Connectivity >> ZMQ remote API server@addOnScript:error] [string "Connectivity >> ZMQ remote API server@addOnSc..."]:439: [string "Connectivity >> ZMQ remote API server@addOnSc..."]:402: Trying to send data to Python where a receive is expected
stack traceback:
    [C]: in function 'error'
    [string "Connectivity >> ZMQ remote API server@addOnSc..."]:402: in field 'send'
    [string "Connectivity >> ZMQ remote API server@addOnSc..."]:511: in function 'coroutineMain'
stack traceback:
    [string "Connectivity >> ZMQ remote API server@addOnSc..."]:494: in field 'resumeCoroutine'
    [string "Connectivity >> ZMQ remote API server@addOnSc..."]:439: in field 'handleQueue'
    [string "Connectivity >> ZMQ remote API server@addOnSc..."]:643: in function 'sysCall_nonSimulation'
Any help would be appreciated! Thanks!!
Re: ZMQ remote API failing after the same amount of runs of a simulation
Posted: 26 Mar 2024, 14:11
can you tell me what revision of V4.6 you are running? You should have revision 16, or better 18.
Also, make sure you upgraded the related pip package too.
Posted: 26 Mar 2024, 16:52
by Llamas0001
I am running revision 18 of V4.6 and im running 2.0.3 of the API as far as I can tell both of these are as updated as they can be so I am at a bit of a loss! I made sure both were updated before testing it to make sure it wasnt a problem with the version!
Posted: 26 Mar 2024, 17:27
Can you provide a minimalistic Python client code that would trigger that error? (maybe with a related minimalistic scene)
Posted: 27 Mar 2024, 13:56
by Llamas0001
#python
from coppeliasim_zmqremoteapi_client import RemoteAPIClient
print("Program Started")
client = RemoteAPIClient()
sim = client.require('sim')
def reload():
    sim.loadScene(sim.getStringParam(sim.stringparam_scenedefaultdir) + '/minScene.ttt')
rightJoint = sim.getObject('/dr20/rightWheelJoint_')
leftJoint = sim.getObject('/dr20/leftWheelJoint_')
objHandle = sim.getObject('/dr20')
robotSize=sim.getObjectSizeFactor(objHandle)
#Numbers here taken from the built in script for the dr20 robot
v0 = 0.4*robotSize
wheelDiameter = 0.085*robotSize
interWheelDistance = 0.4*robotSize
for i in range(10000):
    reload()
    sim.setStepping(True)
    for j in range(100):
        p = sim.getModelProperty(objHandle)
        sim.setModelProperty(objHandle, p)
        sim.setJointTargetVelocity(leftJoint, 5*2/wheelDiameter)
        sim.setJointTargetVelocity(rightJoint, 5*2/wheelDiameter)
        sim.step()
    print("run " , i)
    while sim.getSimulationState()!=sim.simulation_stopped:
        pass
This code reproduces the crash! I think its more to do with time than what the code itself is doing as it takes around an hour-2 hours to crash! For me it crashed on run 4970.
The minScene is just a blank scene with a dr20 in it.
Posted: 28 Mar 2024, 13:28
Thanks, with that I can reproduce the bug. Need to investigate more...
Posted: 02 Apr 2024, 06:19
From first tests, it appears that sim.loadScene is the culprit. This bug somehow also happens with sim.loadModel.
A first workaround would be to avoid constantly reloading the same scene/model: after a simulation stop, the scene should anyways be mostly restored to its original state (i.e. just before simulation started).
Posted: 03 Apr 2024, 08:58
Hello again,
the bug has been identified and will be fixed for CoppeliaSim V4.7, out within a few weeks.
Thanks for reporting it!
