CoppeliaSim embedding into web pages
lumeqi
Post by lumeqi »
May I ask if CoppeliaSim software provides such an interface so that the functions provided on the software can be embedded into web pages.
I want to develop a web application that can showcase CoppeliaSim simulation.
Thank you very much for your answer!
Re: CoppeliaSim embedding into web pages
CoppeliaSim can record a simulation in glTF format (a format for 3D content exchange that embeds meshes, textures and animations), see Modules > Exporters > GLTF animation exporter....
Then you can use a glTF player on your webpage to play back the simulation.
You can also use the web-based CoppeliaSim front-end...
lumeqi
Post by lumeqi »
Thank you very much for your response, it has been very helpful to me. However, if I want to use CoppeliaSim as a server, is that possible? Because if I embed CoppeliaSim into a web page, when users interact with it, they will always be using the same simulation software, which cannot respond to user requests in parallel.
Thanks again.
With the web-based CoppeliaSim front-end you indeed need a corresponding CoppeliaSim running somewhere, one for each independent front-end you want. So this solution doesn't really scale.
