Adding Object Issue
Posted: 13 Jun 2024, 23:59
by gplminhduc147
I wanna add objects with U shape into coppeliasim with python and remoteApi. However, the gravity effects on objects seem wrong.
This is the short record of my issue: https://youtu.be/AWVNzEVxhYU (Full code of remoteApiCommandServer's childscript is under comment)
I've already defined the parameters of these objects in remoteApiCommandServer script:
sim.setShapeColor(shapeHandle, nil, sim.colorcomponent_ambient_diffuse, inShapeShapeColor)
sim.setObjectInt32Param(shapeHandle, sim.shapeintparam_static, 0)
sim.setObjectInt32Param(shapeHandle, sim.shapeintparam_respondable, 1)
sim.setArrayParam(sim.arrayparam_gravity, {0,0,-9.8})
Didn't I do anything wrong here? and how to fix this issue? Thank you
Re: Adding Object Issue
Posted: 14 Jun 2024, 07:28
by fferri
Your shapes are not primitives or convex.
Try decomposing with primitives or convex decomposition.
See also Designing dynamic simulations.
Posted: 15 Jun 2024, 13:43
by gplminhduc147
fferri wrote: 14 Jun 2024, 07:28 Your shapes are not primitives or convex.
Oh I've got this. Thank you for your help !!!
Posted: 22 Jun 2024, 02:49
by gplminhduc147
Hello It's me again. I've already tried sim.convexDecompose() function and the warning disappeared. However, the object's falling look a bit unrealistic (I'll put a link video below). It looks like the evironment treat my shape as a "plane"
https://youtu.be/iXrL4lUxFHs
How can I solve this problem? I'll be very grateful to you if you could teach me how. Thank you
Posted: 24 Jun 2024, 05:53
select your shape, then [Tools > Visualize inertias]: does it look right?
What mass and inertia does your shape have? Did you follow design considerations 7 & 8?
What happens with a different engine?
Posted: 28 Jun 2024, 16:08
by gplminhduc147
coppelia wrote: 24 Jun 2024, 05:53 Hello,
Thanks for your suggestion. I've just set the value of object's Inertia and transform matrix with sim.setShapeInertia. It's working well now.
